Question about JVC Everio GZ-MG21 Camcorder
I NEED TO RESET THE DATE AND TIME - JVC Everio GZ-MG21 Camcorder
Posted by JOHN HASKINS on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • JVC Master
  • 102,366 Answers
The "Clock Adjust" command is in the REC menu. See pages 52-53 of this manual.
Posted on Dec 29, 2012
How do I reset time and date on SioScan Atomic Clock? I need Arizona time zone - i.e. no daylight savings time
Put it into settings and then adjust time/date. It's not related in any way to temperature.
Apr 24, 2015 | Home
Time/date won't retain
The camera's internal date/time "backup" battery is supposed to maintain the date/time for about 3 weeks with the camera turned off. If the camera is not used for a longer period, the date/time will need to be reset. If you are having to reset sooner than that, it is likely that the internal battery (not user replacable on most models) has failed.
Aug 20, 2014 | Canon PowerShot Cameras
Change time
1. Begin on the main sales screen
2. Press the purple MORE key twice
3. Choose OTHER SET UP from the display screen
4. Type in your password if applicable
5. Press the purple MORE key until the display reads SET DATE/TIME
6. Choose SET DATE/TIME from the display screen
7. Type in the date mm/dd/yyyy
8. Type in the time HH:MM:SS in Military Time
9. Press ENTER
10. Press the red CANCEL key
Mar 11, 2012 | VeriFone VX510
The time/clock on my computer is 2 hr.s slow.
click start control panel date and time you can make your adjustments to the date and time from there or right click on the date and time and you should see Adjust date and time tab hope this helps
May 27, 2011 | Computers & Internet
Need to reset the date and time.
press the dataregistration button,press set,use the arrows to scroll down to usersettings,press set again,time&date will be displayed,press set and change the date and time.
Jun 02, 2009 | Canon FAXPHONE L80 Laser
Can't find my manual and need to reset the date and time
if system DK series must set at port "00"
#402 to check the port number with displayed phone
#651 DDMMYY - for date
#652 HHMMSS - for time
#653 to change the day
Apr 08, 2009 | Toshiba DKT3010SD Corded Phone
TIME DATE LOCK 0271
This IBM 0271 error code means the Date and Time setting in the BIOS is incorrect and needs to be reset in the BIOS configuration.
This is caused by a dead or nearly flat BIOS battery.
You need to replace the BIOS battery and reset the Date and Time.
Apr 08, 2009 | IBM Computers & Internet
Ativa at-p3000 adding machine....no user manual or way to set ate and time
To set the time: Press the date/time button (next to the feed button) to make the time appear on the display. Then press and hold the "Time Set" button (the "=" button) until the first digit of the time setting begins to flash. Then just enter the current time with the keypad (3:30 is 0-3-3-0) and use the "AM-PM" key (the "x" button) to toggle am/pm. After you have the time entered, press and release the "Time Set" (=) again to set the new time.
To set the correct date: Press the date/time button (next to the feed button) to make the date appear on the display rather than the time. Then press and hold the "Time Set" button (the "=" button) until the first digit of the date begins to flash. Do the same as before to set the new date. Don't forget to press the Time Set button after you set the date or it will not record the change.
If for some reason you need to reset your calculator, turn it over and stick a pencil into the reset hole next to the battery compartment. That will reset everything.
Dec 14, 2008 | Computers & Internet
Date & time reset
try and enable automatic update of time and date in the settings..
Nov 02, 2008 | Nokia 6300 Cellular Phone
Wrong date on the radio.
RESETTING THE CLOCK AFTER A TOTAL MEMORY LOSS
If you do not change the built in lithium battery within a reasonable period of time after you see the ‘flashing’ LOW BATT. warning indicator, the lithium battery may become exhausted and will no longer be able to supply back up power to the SmartSet internal computer.
If the unit is disconnected from the AC outlet after the battery is exhausted, or if a power interruption occurs, the SmartSet memory will be lost and the clock will need to be reset when the power is restored. Be sure to install a fresh lithium battery before you reset the clock, otherwise the clock will need to be reset each time the power is interrupted.
If the lithium battery is exhausted and you experience an interruption in the AC power supply, the clock will reset itself to its initial default setting when the power is restored.
The initial default setting is “12:00 AM, Saturday, January 1
(1 1), 2005”.
If you notice that the time on your SmartSet clock radio is completely incorrect, and the day indicator is also wrong, press the MONTH/DATE button to see the date. If the date display is showing “1 1” (January 1 ), you probably experienced
a total memory loss. To reset the clock after a total memory loss, proceed as follows:
1.) Install a new CR2430 lithium battery in the battery compartment.
2.) Connect the radio to your AC outlet and let the clock set itself.
3.) Depress the MONTH/DATE and TIME buttons together. The display will change from ‘time’ to ‘year’. While holding the MONTH/DATE and TIME buttons, press the UP button to
set the display to the correct year, then release the buttons.
4.) Depress the MONTH/DATE button. The display will change from ‘time’ to 'month/date’ (mm/dd). While holding the MONTH/DATE button, press the UP button to set the display
to the correct month and date. The Day indicator will change automatically as you adjust the month/date settings. When the correct month and date appear on the display, release the buttons.
5.) Depress the TIME button and the UP button to set the display to the correct time. Be sure to confirm that you have set the time correctly to ‘AM’ or ‘PM’ by observing the AM indicator.
6.) After you set the time, reconfirm that the Day, and Month/Date displays are still correct. Make final adjustments if necessary.
The SmartSet clock memory is now reset and the new lithium battery will maintain it for the next 5 to 8 years, depending on the number and duration of the power outages you experience.
IMPORTANT NOTE:
After resetting the clock, don’t forget to reset your wake up times, and alarm mode settings, and sleep timer settings as well.
Oct 22, 2007 | Emerson SmartSet CKS1850 Clock Radio
JVC Everio GZ-MG21 Camcorder Logo
62 people viewed this question
Top JVC Video Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Larry Stiles
Larry Stiles
Al Rush
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
