Question about SYMA Toys industrial New Syma S107 Radio Remote Control Helicopter
My S107g worked great for a week but then the top blade just stopped moving. The lower blade is spinning away and the top one sits there limp. What's going on?
Posted by NewChopperGuy on
Rishi Roshan Ali
  • 2,427 Answers
Well firstly you still have warranty on it, get them to replace it..
the blades are controlled by a motor and a gear system in the helicopter itself. The gear is broken or the motor is wedged in by the gear. or simply burnt out, You will need to open it to unwedge the gear and if it spins when you turn the gear, you need to replace the motor. Both blades use separate motors that's what allows it to trim (turn) when one set spins faster than the other, It goes straight when both blades spin at the same speed.
Posted on Dec 29, 2012
Remote not working
I would suspect a fault but check the batteries in the remote are fitted
correctly.
Jan 28, 2014 | Syma GIFT SET 2 S107G R/C Helicopters Blue...
S107G upper blade doesnt rotate,and leans to the side. lower blade spins...but no take off. brand new out the box......sup?
Check that the bottom gear/cog is engaging with the motor drive gear. This is a common fault and usually just need to move the cog on the motor.
Kind regards, Julian
rccontrolfreak.co.uk
Oct 25, 2013 | SYMA Toys industrial New Syma S107 Mini...
My S107G Metal Series will not take off just sits and spins how can i fix
If there are two blades that turn in opposite directions, perhaps the blades are reversed. If that is the case then they are pushing the helicopter down instead of up.
Sep 09, 2012 | SYMA Toys industrial New Syma S107 Mini...
Blade brake dosen't work right away when switch is released. Takes a couple seconds of slow spin then the brake seems to stop the brake. Suggestions?
All blade brakes take a moment to stop the blade. If it were to engage as soon as the switch were released the inertia of the blade would do damage to the saw. Look at videos of your saw on youtube to ensure it is operating the same as others.
Jun 12, 2012 | Ridgid Reconditioned 12 In. Compound Miter...
Vitamin 3600 canister leak
I think it's the little washer in the blade assmbly since mine was worn to a sliver when it started doing what yours did. I replaced it with a similar washer and it worked for a week and then started spitting out metallic dust until it stopped working again. Could be the bearing seized. I would say yes a new blade assembly but I hadn't found one- since I have a 3600 which is very old-when my husband bought a used replacement container with a working blade assembly on ebay. $37 bucks, problem solved.
Mar 28, 2012 | Vitamix Blenders
My S107 does not hover very well. It moves in a large circle on its own. It isn't the trim as it doesn't spin around the axis of the rotor. It points in the same direction but slowly moves left, back,...
The upper shaft 'T' head has a broken pin in it (the part that holds the blades. You can flip the heli upside down and slightly rotate the blade housing back and forth and IT SHOULDN'T do that. Another way to instantly identify it is dislocate the rotor head links and the upper blade housing should instantly separate) It's made of plastic.
Anyway, It's also called the "T.B.E." Toilet Bowl Effect. It's not 'really' what's taking place, it's move of a cyclic issue but the effect looks like it's swirling in a toilet bowl... You need to replace the inner shaft basically on the upper rotor. They cost anywhere from $4-7.00 bucks. It took me about 2 days of researching and purchasing another one to finally figure it out. There was another website that says the balance bar is it or the gyro has gone bad; this simply isn't true.
Cheers!
Jan 05, 2011 | SYMA Toys industrial New Syma S107 Radio...
I've just moved into a home with an existing Armstrong Concept 10 A/C unit that's at least 15 years old. When I left for a 2-week vacation, the unit was working great. I set the thermostat to 77 to save...
Hello 93 The compressor caused the breaker to trip.A weak capasitor or burnt wire is a common cause.It sounds like the compressor is NOT on even though the fan is.It may need a new wire or maybe a HARD START kit to help restore operation.Call for help.HS kits are not expensive.NO damage results from leaving it on, the problem would have happened anyway even if you went on vacation or not.The curcit breaker stopped it.Its worth fixing.
Aug 30, 2010 | Heating & Cooling
My Magtag Ensignia does not spin
Just had a similiar problem a couple weeks ago. There are some small parts in the agitator called "dogs". Here is a picture:
The "dogs" are the 4 small parts in the lower right. They need replaced. It can a little tricky but they are relatively inexpensive. Mine were $6.
Aug 13, 2009 | Maytag PAV2300 Top Load Washer
MAYTAG LAT8506AAE WASHER - TERRIBLE NOISE/VIBRATION ON SPIN
Try this for re-setting the balancing mechanism:
With the washer empty, tip tip it forward so that it is just sitting on the front feet. Hold it there for a few seconds, then gently lower the back down. (Often there is a mechanism in the back feet that automatically levels it for you--if this doesn't work, check that the back feet are not damaged.)
Mar 16, 2009 | GE WPGT9360EPL Top Load Washer
Blade not spinning
My Vitamix 3600 plus has same problem. Result of detachment of rubber coupling between lower splined socket from blade shaft. This is a tough rubber molding that takes tremendous punishment through years of smoothies. Mine showed some rust on the bottom of the blade shaft, where it parted. I tried gluing back together with super glue and tried to eyeball it. Of course it was off by a few degrees. When I reassembled and turned it on, what a racket of vibration! But it held. Amazing. Obviously not good to go though. So I took assembly all apart and redid it, chucking the shaft and the lower nut in the lathe. This time, all true on axis. Glue held for about a week. Right now I am regluing, this time with epoxy. We'll see how it holds up. And meanwhilst, I'm researching replacement parts! I'm not too optimistic about the epoxy.
May 28, 2008 | Vitamix 36000 Work Top Blender
SYMA Toys industrial New Syma S107 Radio Remote Control Helicopter Logo
289 people viewed this question
Top SYMA Toys industrial Toys Experts
ray gallant
Tom Chichester
Jeff Waters
Jeff Waters
Level 1 Expert
Are you a SYMA Toys industrial Toy Expert? Answer questions, earn points and help others
