Question about my HP desktop model p6-2003 computer blue light on and moniter going to sleep moniter going to sleep
Have owned dell this is my first hewlett packard fist the icons left fixed that and now I haft to shut off power and then it comes on and works. I am on it now. but earlier moniter would go to sleep while computer was on whats wrong?
Posted by penny cornelius on
Rishi Roshan Ali
  • 2,427 Answers
In control panel, select the power Options,, Change the preffered plans to HIGH PERFORMANCE then click on change plan settings, change turn of diaplayto never and put computer to sleep never... Remember to turn on your screen saver and put the pc to sleep manually when not using it.
this is a common problem and caused by corrupted registry entries. The popper fix is to reformat or restore the system.
Posted on Dec 29, 2012
5 Related Answers
Anonymous
  • 36 Answers
SOURCE: dell desktop
Resolving the blank screen Follow the instructions below in order to fix this issue:
  1. Remove any CDs, DVDs or memory cards from the computer.
  2. Disconnect all devices from the computer leaving only the original mouse, monitor and keyboard and power cord connected.
  3. Restart the PC.
  4. Press the F1 key repeatedly during the first startup screen until the entering setup message appears.
  5. Press the F5 key to restore the default settings. Use the arrow keys to select YES and press ENTER .
  6. Press the F10 key to save the changes and exit. Use the arrow keys to select YES and press ENTER . The PC restarts.
  7. When the system restarts select Last Known Configuration from the boot menu. The PC should now startup normally. If the blank screen persists continue with the following steps.
  8. Select Safe Mode from the Windows Advanced Options Menu .
  9. Use Microsoft's System Restore feature to restore your computer to an earlier time and correct the issue.
  10. If disconnecting devices from the PC resolved the startup issue, re-attach one device and then restart the PC. If this is successful, re-attach the next device and restart the computer again. Repeat this process until you find the device that is preventing the PC from starting properly. Contact its manufacturer for advice on this issue. Please, keep your PC software updated in order to possibly prevent the error from occurring in the future:
    • update Windows.
    • update the BIOS.
    • The software for the devices may need to be updated or reinstalled. Contact their manufacturer for information on the latest updates for your devices.
Posted on May 21, 2008
Anonymous
  • 23 Answers
SOURCE: i have a cisnet not exactly sure what model my sister gave me
chack the monitor cable with c.p.u and other probleam is your R.A.M is not work fine
Posted on Feb 15, 2009
Anonymous
  • 60 Answers
SOURCE: Picture is too big on computer moniter
try to change the Display settings with a higher resolution, example 1024 x 768. It's under control panel - Display and Settings Tab.
Posted on Apr 01, 2009
benwabnick
Ben Wabnick
  • 2404 Answers
SOURCE: HP Slimline Pavillion s3123w monitor going to sleep.
Sounds like the motherboard might be bad but go thru these steps.
Unseat and reseat the memory one stick at a time in each slot one at at time and turn on the computer after each stick reinsertion.
If that doesn't get the video to come back up then go ahead and unseat and reseat the CPU. Then try turning on the computer.
If that doesn't do it, make sure there is no power going to the hard drive or the dvd drive. Then try turning on the computer.
If you do all of these steps and you still have no video, then the motherboard is bad and would need to be replaced.
Posted on Aug 19, 2009
Anonymous
  • 8 Answers
SOURCE: Solution for
HP has been really great with my pavillion desktop and its out of warranty and they still help me with the issues and help me solve them it may take a while to get it taken care of you may have to emial back in forth to get your promblem taken care of. Here is the email support that you can try just provide the modle number and the serial number that should be located on one side of the computer or on the bottom of the tower, and Good Luck!
[email protected]
Posted on Jan 06, 2010
System doesn't get on after shut down
Check the system BIOS. I know that in certain HP systems you can disable the power button so that it doesnt do anything. It's to stop the system being accidently shut down
Jan 26, 2014 | HEWLETT-PACKARD Hewlett Packard HP...
Fixya solutions:: my question is about my Hewlett Packard model p6-2003W desktop blue light on ucp and moniter going to sleep and shutting off when I reboot or shut off power they both come on and I a
The problem can be correct in the control panel power options..
select hig performance as the preferred plan,
click change plan settings
change both sleep options to never>>
this is caused by a corrupted display settings in the registery and needs to be reformatted or restored using the factory restore disc to fix the problem. the above solution will work just remember to put your system to sleep manually and turn of your monitor.
Dec 29, 2012 | HEWLETT-PACKARD Computers & Internet
MY HP 110 Notebook has no Wifi connection available
Switch on front edge below the keyboard ,see users manual page 10:http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c01757458/c01757458.pdf
Nov 07, 2012 | HEWLETT-PACKARD Hewlett Packard HP 110 -...
My volume went low.
These are speakers with their own power?
No? - Get some.
Yes - Win7 - If you speaker icon is missing go to Start > Control Panel > Hardware and Sound > Manage Audio Device > Sound. In Playback Check levels and configure speaker setup, like 2.1 or 5.1.
You should also check speaker connections for left speaker.
Oct 11, 2012 | HEWLETT-PACKARD ProBook 4520s
I have probook 6500b and no sound coming out of the speakers while the head phone is working properly
did you unplug the headphone ? they wont work at the same time.
check if speakers are enabled and not set to mute in your sound settings (bottom right of the screen, rightclick on the little speaker icon, settings)
Jun 20, 2011 | HEWLETT-PACKARD Hewlett Packard HP ProBook...
My packard dell does not power up at all. no
check your power adapter to see if the light is on the adapter to indicate it is getting power to your system
Jan 23, 2010 | HP Hewlett Packard Dell XPS M1330 Business...
Computers & Internet Logo
Ekse
Marvin
Marvin
