No help! When I dragged the file icon onto the balnk disc, it initiated the format process. I answered that I did not want to format the disc, the process terminated and closed the window. There is no alternative to formatting, and when I try to drop something on the disc, I just get the message "disc is write-protected".No help! When I dragged the file icon onto the balnk disc, it initiated the format process. I answered that I did not want to format the disc, the process terminated and closed the window. There is no alternative to formatting, and when I try to drop something on the disc, I just get the message "disc is write-protected".
It correct term would be "Finalized", you would need to erase the disc to be able to write ti it.It correct term would be "Finalized", you would need to erase the disc to be able to write ti it.
The different codes are telling you, there is a copyright protection on the sound or the video. Sometimes parts are protected, because it was intended for other use.
See the link to: Cinavia Messages Message Code 1
you can remove the right protection from the computer you use to create the right protection, if you want to use diferend computer that's impossible but same you can go to start and type CMD the comand prompt once the (CMD) folder will open, type (discpart) another (CMD) folder will open type list disc that is going to highlight all the disc on your computer or laptop, now type select disc and exact number of the flash drive if it's 1 2 or3 and hit enter it will select exact number with the flash drive, now attribute clear readonly and enter, now it will says attribute successfully, now type exit to see changes remove the flash drive and plug it back done
It has password protection. Open My Computer on your PC, insert the USB drive, open the password file, enter your password, then select the option to remove password protection from the USB drive. If this does not work, contact Verbatim for a solution, these USB flash drives have lifetime warranties.
With CDRW discs you just need to erase it before you use it again. I use a program called NERO to erase it. Once erased the formatting is done automatically when you're ready to put something on the disc. However, when the writing is completed, you'll have to erase it again to write new data to it.
I assume it means just what it says. The Disc you are trying to copy is faulty?
Clarify what you are trying to copy. If it is copy protected, A duplicator wont copy it. Or the disc was made in a format incompatible with the master drive you are using. Ive had drives read some discs and another drive that cant read the same disc. Some brands of discs work better on certain drives. Try to use top quality reccomended discs such as Verbatim.
It's very odd that an never used disc would be finalized though.
