Question about Craig CMP741d Tablet
Cant turn on my Craig Android Tablet...
I have pressed and held the reset button and nothing is working.
Posted by Belle on
  • 2 more comments
  • Anonymous Mar 12, 2014
    I followed the instructions I held the power button and the column up button down at the SMS time nd the menu did not appear
  • Anonymous Mar 19, 2014
    my tablet say it is loading. but it not starting. i have reset it. how do i get to work.
  • Anonymous Mar 21, 2014
    tablet gets stuck on the android screen. reset button did nothing to fix problem. Tried holding power and volume buttons. Nothing. any help would be great.
  • Anonymous Mar 24, 2014
    Cant turn on power is there another way to turn it on
    Is there another way to turn it on without a power button
Justin
  • Craig Master
  • 2,072 Answers
Is it charged, does it charge properly? It may just be dead.
Posted on Dec 30, 2012
  • JEM Feb 16, 2015
    how old is this device? how many times dropped?/
3 Related Answers
Tanuj Handa
  • 66 Answers
SOURCE: i cant get in my gmail from my craig tablet
Please check what error message you are getting and type the correct password.
Posted on Dec 28, 2012
Dendariarena
SOURCE: my craig tablet keeps coming
Low memory for android process. Update slideme from www.slideme.org and then install eveything on the micro sd. Let the tablet memory free for process. I know this because a got the same tablet with the same problemm until this. First return the tablet to factory default
Posted on Jul 23, 2011
White Zombie
  • 4961 Answers
SOURCE: i have a craig touch screen tablet and i forgot my dot password how do i reset it?
Power the unit off (holding power buttom) and selecting Power off, then hold simultaneusly back button and on buttom 8 seconds,the android icon appear press back buttom, in the menu select wipe data/factory reset pressin home buttom and then press back buttom, in the next screen select "yes delete all user data" pressig back buttom, and in the nex screen select "reboot system now" with the back buttom and wait. IT WORK FOR MY TABLET
Posted on Aug 19, 2012
Tip
Resetting a Frozen iPad
If you encounter an iPad problem that causes it to freeze, or if it is sluggish when you tap on an app, try a hard reset.
  1. Press and hold down the sleep/wake button at the top of you iPhone or iPad while at the same time, pressing and holding down the Home button on the front of your iPhone or iPad.
  2. Keep holding both buttons held until the screen turns off. It will automatically turn back on again and display the Apple logo.
on Dec 08, 2014 | Apple iPad Tablets & eReaders
Okay my sister had her tablet she turned it on and it froze at the go screen. So I pushed and held down. The power button and it turned off, and then I don't know why I pressed the reset button but it...
Do a factory reset. Remove all power including internal battery. Let the unit discharge completely. Plug into external power supply and try to start up. If it starts. shut down, put the external cord out , replace internal battery, and recharge for an hour. Now try a strat from the internal batter. If it fails, that s the problem.
Feb 03, 2015 | Tablets & eReaders
I do a hard reset get to the menu and when i press the power button to reset it dont do nothing?
you did not say what it is you are trying to reset . Desk top , laptop , tablet ?
Jan 02, 2015 | Tablets & eReaders
How do i reset my android dragon touch tablet
Try holding power and both volumes if it reboots normally try again but let go of power when the Android pops up
Apr 17, 2014 | Tablets & eReaders
Cant reset tablet
Press and hold the vol - at the same time press the power on button
Apr 02, 2014 | Tablets & eReaders
How to reset tablets
Do a hard reset, press and hold the +vol button, then the power button, wait about 20 seconds both buttons held till the start android screen appears. Hope that helps
Mar 24, 2014 | Proscan 7-Inch Android Internet Tablet,...
My nexus 7 wont go past multicoloured x.. cant switch on/off. tried hard reset and nothing works
Important:Plug your device into power outlet
Step 1: Power off Nexus 7
Step 2: Power on while holding Volume Down/Up
(enter BootLoader)
Step 3: Press Volume Up to toggle to "Recovery Mode"then press power to select
Step 4: Hold The Power Button and tap Volume Up when you see "No Command"
Step 5: Press & hold Power Button & Volume Up Button Again
Step 6: Toggle with vol down and vol up / power at wipe data (all data) & reboot
Nov 20, 2013 | ASUS Google Nexus 7 8GB Tablet Unlocked...
Help forgot pattern and registered gmail acct to unlock tablet
If you don't know the account then you will need to factory reset the tablet. For most tablets you will need to power off the tablet completely. Power on the tablet and immediately press and hold power + vol down until you get a menu. Select Factory reset.
Jul 06, 2013 | Tablets & eReaders
Forgot my unlock pattern
This does not work. I am getting nothing. Please help
Aug 19, 2011 | Coby Kyros 716829701508 Tablet PC
Craig CMP741d Tablet Logo
459 people viewed this question
Top Craig Tablets & eReaders Experts
Lawrence Oravetz
john h
 Mikey
Mikey
Are you a Craig Tablet and eReader Expert? Answer questions, earn points and help others
