BenQ GH600 Fashion Chic 21X Optical Zoom Long Focus Wide Angle Cameras Logo
Posted on Dec 28, 2012
When ever i press photo click button my camera shuts down. It works fine when viewing photo. Even when i gentel press dat button to go on photo taking mode the camera goes down. Even I can video on clickng the photo shoot button.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Dec 28, 2012
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
Helped
568
Points
11
Make sure your camera is fully charged. Sometimes when it is almost out of power it will shut down.
2 Related Answers
Anonymous
  • 2985 Answers
  • Posted on Aug 31, 2007
SOURCE: Not able to take photos
Send it back to the retailer if in warranty or contact BenQ support for a repair/replacement quote
Shankar R
  • 206 Answers
  • Posted on Apr 13, 2011
SOURCE: Every time i press the
Hi, the issue is with Batteries. Please replace the Batteries of same specification in order to use the Digital Camera. The Photos in the Memory Card is powered by USB as the Power Source from your Computer and not your Camera's Batteries. So please replace the batteries with new one.
1helpful
I have turned camera on and set up to take a photo and the shutter release button will not press in to take the photo. I used the camera yesterday and it worked fine!
Turn the camera on and look into the view finder while you try to press the shutter button. Check the information in the view finder to see whether you are getting an error message. If you see an error message in the view finder, remove the lens cap and proceed to take a photograph but, instead of pressing the shutter button this time, press the button near the top of the camera on the back which says "AF/AE. If the camera takes the photo it means you have somehow initiated the auto focus/auto exposure lock which the camera will not override when attempting to take a photo using the shutter button. When you use the AF/AE button, you override this system. To remedy this issue, when you get the error message try pressing the shutter button again. Also, remove the lens to see if the shutter inside has frozen in the "locked" position. If you find this to be the case you will need to contact Nikon Customer Support. The link for Nikon Support is below. The numbers are half-way down the page.
http://support.nikonusa.com/app/answers/detail/a_id/238
3answers
Camera turns off when taking picture
Try changing the battery brand and see if this helps..I seem to have the same issue with my camera with certain battery brands..Solved my problem by switching brands..
How to view photos
To view them on the camera lcd screen, press the playback button (green arrow in a green box, 2nd button down to the right of the screen) and then scroll through them one by one using the left and right buttons on the thumb pad. If you press the up and down buttons the image will advance forward and back by ten pictures each time.
To view them on a tv, turn the camera off and connect the video cable supplied with the camera to your tv input terminal (yellow). Turn the camera on set the tv to display the input feed and then use the camera playback button as before.
To view them on a computer, you'll need to upload them to the computer first. The best way is to turn the camera off and remove the memory card, and then insert it into a memory card reader connected to your computer. The computer will then prompt you to upload and display the images.
For full camera instructions from Olympus, click here.
For basic operating instructions, click here.
Please take a moment to rate my answer.
Faulty power button finepix
The on/off and picture buttons are run from a little ribbon strip that fits under the main pcb. I have pics to help you. Just click on "THE ONLY WAY I KNOW HOW " In the tips & tricks section for my email address.
Thanks
Camera turns on then shuts down
hi...ensure  that the camera is turned on. If applicable, ensure the lens cover has been removed before taking pictures. the LCD backlight is turned on by pressing the DISPLAY button several times until the screen appears.  Depending on the camera model, the DISPLAY button may be labeled as DISP or with a display icon. This button could be a standalone button or it depends upon the camera model.....
If operating the camera with a battery, ensure the battery is fully charged.
Ensure the battery is inserted properly in the camera.
If operating the camera with the power adapter, ensure it is plugged into a working AC outlet.
Ensure no Audio/Video (A/V) cables are connected for viewing pictures on a TV; the LCD screen will not display when an A/V cable is connected.
Perform a reset procedure on the camera....
thank u rate me!!!!
Camera turns on but shutter does not open. green light comes on then it beeps twice and shuts down. You can view pictures fine though
You mean SD400 camera doesn't show any error sign and it just doesn't have live view to shoot picture?
If yes, its problem of bad CCD imager and Canon will provide free of cost repair facility for SD400 camera.
Click Canon CCD Advisory for details.
Shutdown sometimes fails - Lens retracts then immediately extends again
I am having the same problem with my camera. I have to take the batteries out to get it to shut down. I also cannot view my photos on the camera, when I try to turn it to view, it goes to shoot mode.
Ccd error
Sounds like your 'preview' feature has been turned off in your camera settings. With the camera turned 'on,' press: "Menu," then press the joystick button until you reach the pencil, which is your, "Custom Setting Menu." Then press down on your joystick to reach, "Image Review." Now press the joystick to the right to select, "Image Review," and press up on the joystick to get to, "Image Review On," and then press, "OK." If that doesn't do it, please let us know.
3helpful
7answers
Deleting from memory card
1. Set camera to playback mode and turn on.
2. Push "W" on zoom button (zoom out). (this will show you the index card)
3. Press the delete button (garbage can button)
4. Choose the top option "All In This Folder"
5. Confirm choice.
Shuts right off - now lens won't go in
I was having the same problem and tried several set of new batteries. Finally I purchased a set of high performance lithium batteries and the camera works on them. Before trying to get repairs or buying a new camera try spending $15 on the best batteries you can find.
Top BenQ Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Eric
ADMIN Eric
Tony Parsons
Tony Parsons
Are you a BenQ Camera Expert? Answer questions, earn points and help others
