Samsung DVD-P231 DVD Player Logo
mark e foster Posted on Dec 28, 2012
Disc inserted but not recognized , no disc is the display
1helpful
I have a Sony Psyc CD Walkman D-Ej010 and I will have a cd in there at it will play for a few minutes and then stop and say no-disc. What could be the problem?
There may be a couple of reasons why a NO DISC , DISC ERROR or INSERT DISC error may appear in the display of your CD player. Try doing the following steps to troubleshoot why the error is displayed:
  • For disc players with a HOLD switch, make sure to move the switch to the OFF position.
  • Verify that the disc being used is supported by the CD player. NOTE: CD players do not support VCD or DVD discs. In addition, some CD players do not support CD-R or CD-RW discs that are created by a CD burner. For information regarding disc compatibility with your player, refer to the operating instructions supplied with the product
  • Ensure a disc has been inserted into the player. Make sure that the disc is inserted correctly, with the playback side of the disc facing down on the disc tray.
  • If the disc still does not play, attempt to play a different, commercially-produced disc.
  • NOTE: If more than one of the commercially-produced discs do not play, verify whether the discs are extended-length discs. Some players are not able to play discs where the recording exceeds the standard 74 minutes. If the recording of the disc is longer than 74 minutes, it is possible that some of the specifications of that disc were compromised and therefore, the CD player will not recognize that disc.
  • If the disc is dirty with fingerprints or smudges, or if the disc is scratched or broken, the CD player may not recognize the disc.Clean the disc using a soft, dry cloth.
  • Properly reinsert the disc into the player.
  • Attempt to play the disc again.
  • Only press the PLAY button once. If the PLAY button is pressed more than once, the disc may stop playing.
  • If the disc is still not recognized, remove the disc and leave the CD player powered on for approximately one hour to resolve the possibility of moisture condensation inside the player.
  • Please use a Lens Cleaning disc and check if that helps.
If the issue persists, please click hear to locate the repair facility near your area.
Thanks for understanding. Please let me know if you require any clarifications.
DVD Player does not recognize disk and displays 'insert disk' message.
Sounds like compatibility issues, your player maybe old enough not beable to recognize newer disc.
1helpful
RCA RP-9515 stereo, CD player won't play
RD probably stands for "Reading Disc" and ND probably stands for "No Disc". If the CD player doesn't recognize any discs, then either the laser is dead or the motor has died. MOst likely you will have to replace the unit.
My NAD cd/dvd T550 displays NO DISC.
I have the same problem. When I insert a disk, my NAD T 550 DVD player displays 'No Disc'. It started with new disks while still reading older disks, but at some time it stopped recognizing any disk. Did you receive any suggestion yet or has anyone a suggestion?
Games,movies wont play
i tried to insert to game cd but the response was negative the game icon never appears on the screen so post me a solution for this in my mail
2answers
CD DRIVE - NOT RECOGNIZED
If you are having a problem with one particular cd.... examine it for scratches or smudges.
Robert
2helpful
DMR-EH75V DVD Recorder
ekimt,
Yes, it would not recognize any type of disc. The disc icon was always present on the display even though no disc was inserted. Also, mine went out while recording from HDD to DVD. Panasonic had mine repaired in two business days and it' s working great.
mjs8
DVD Player Displays 'Disc Error'
try a cleaner disk, if that doesnt work, junk it and buy something better than this one...cheap dvd players have a habit of not working very long....
2answers
No disc displayed
The disc won't spin until the unit recognizes that there is actually a disc there. Try cleaning the lens using a cotton swab and alcohol. If that fails, try playing a CD. If the CD plays, the optics are starting to fail as reading a DVD requires higher laser power.
Dan
2answers
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
