Question about Kitchen Appliances - Others
Popcorn machine model tpc-603 manual
David Sherven
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 5 Answers
Treat Time Model TPC-603
Turn on light and popcorn buttons, for 2 minutes to heat up the popper's kettle.
Then turn off the popcorn button, this stops the turning gears while loading oil and popping corn.
Warning the stainless steel kettle will be hot. Might want to wear an oven mitt.
1 tablespoon of oil (I use coconut oil) and 1/3 cup of popping corn. This makes est. 6 to 8 cups of popcorn.
NOW turn on the popcorn button so the gears start turning, this turns a wire on the bottom inside the kettle to keep the kernels from sticking or burning to the bottom.
If making multi batches, during the process it states in the manual to allow it to cool 5 to 10 minutes. I normally pop 3 to 4 batches and then let it cool down.
When finished popping, turn off both the light and popcorn buttons.
Posted on Nov 25, 2017
1 Related Answer
Gerrit Berglind
  • 55 Answers
SOURCE: I NEED THE MANUALS BELOW:
Try their Manuals and Diagram Locator at: http://74.222.63.157/Net2009/DocLoc-set.htm
Posted on Oct 27, 2010
Need manual for focus electrics model 82512 popcorn popper
Hello, Tbibbe357 -
Focus Products Group owned the West Bend brand name until late 2016 when The Legacy Companies acquired the West Bend Electrics division.
Therefore, your "Focus Electrics" popcorn popper, model 82512, is also known as the West Bend Stir Crazy Theater-Style popcorn popper.
I found the manual for your machine on the West Bend [company] web site. You can link to the manual here:
https://www.westbend.com/support/user-manuals/popcorn-poppers.html
Choose the link to the for:
82512 - Theater Popper, 2.5 oz.
The manual is in PDF format, so you will need Adobe Reader software (free) to download it, save it to a file in your Documents folder (suggested name for the manual file: Popcorn Popper Manual), and print it for easy reference.
Best wishes.
Jan 14, 2018 | Kitchen Appliances - Others
What is the corn and oil amount for treat time popcorn popper tpc 603
I am not fimiliar with that brand . the corn/oil ratio is 3 to 1 so if you add 1-1/2 cups (12oz.) of corn with 4 oz. of oil the popping cycle from the time you dump the corn and oil in to when you dump it shoul be around 3-1/2 min. if its much longer its too much so try 8 oz of corn and 2-1/2 oz. of oil. By you using this test or formula I am assuming the kettle thermostat is set correctly already.
Jan 22, 2016 | Kitchen Appliances - Others
How much oil and corn to put into machine ttc-603
1 cup an 1 teaspoon or table spoon depending on oil . some get hotter .
May 09, 2015 | Kitchen Appliances - Others
NEED PARTS FOR TT model no: TCP-603
replacement parts are not sold or available for that model. Try bringing the broken one to a small hardware store to see if a replacement can be crafted,
Dec 02, 2013 | Cretors Kitchen Appliances - Others
Need operation manual for singer model 603 sewing machine where can I find one?
If you haven't located the manual yet it is available as a PDF on the Singer web site and it's free to download. (-:
Sep 29, 2011 | Sewing Machines
Do you need to add anything to the popcorn machine
Depends on your machine. What bran/model dso you have? If it is an air popper, NO. Adding anything will damage the machine.
If your machine is not an air popper then you likely need to add some oil. I currently have a WestBend Stir Crazy Popcorn Popper. You use a tablespoon of oil for each 1/4 cup of popcorn in the bottom of the popper. See here; an instruction manual is available.
You are best to check with the manufacturer of your popccorn popper.
Jan 30, 2011 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
766 people viewed this question
Top Kitchen Appliances - Others Experts
Marvin
Marvin
john h
Tom Chichester
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
