I am running off of windows 7 on my PC & Laptop and of coarse apples on my ipads & imac. The printer always shows ready but nothing prints, what is going on here?
SOURCE: Cannot print with wirelessly networked printer
hi,
if printing from 2 other computer works fine, will i think its not an issue of IP address which changes somehow. but anyways, try to check if you still have other printer drivers under "PRINTERS" (see control panel). it should say HP Photosmart c6100 series. If you also have there a printer icon that says HP Photosmart c6100 series Copy1, try using it (right click on that icon and choose Set as Default Printer). If you only have HP Photosmart c6100 series under PRINTERS, try to right click, then choose properties. When Properties box is open, click on PORTS tab. then click on configure ports below. Try to type in the IP address of the printer under "Printer Name or Host name or IP address". make sure that you already printed network configuration page to get the exact ip address of the printer, Dont know how to print? do this.
PRINTING NETWORK CONFIGURATION PAGE
1. press setup, then scroll down and look for Network.
2. press okay on network, it will give you the first option "VIew network settings".
3. press okay on it, and it will give you the first option "Print network configuration page."
4. choose that and press okay. it will print the network config page. from this document, you will be able to see the IP address of the printer.
Please let me know if the issue is still not resolve so that i can go ahead and give you another possible solution.
Thank you so much.
adonscott
SOURCE: print spooler not running
to
make spooling work its necessary to make it work
this is the procedure .if you do this it will work properly. till it is not
done it will just ignore printing
1)click the start in the left sice of your computer screen
2)go to control pannel
3)click performance and maintainence
4)click system
5)click data execution prevention
6)turn on DEP for essential windows program and services only.
7)click the spooling services a tick mark sign will appear beside that means it
has enabled.
now your printer will work properly.
thanks.
SOURCE: Can't print to HP 2600n over network
The LaserJet 2600N has a built-in print server and can be connected to the local network (normal ethernet cable) directly. While printer sharing via Windows should work, I found it much more convenient to access it without the need of a hosting computer - you do not need to switch on the desktop PC for printing from the Laptop, for example, its also printing faster.
SOURCE: Printer says "ready" but won't print
u r saying printer doesn't print,pls check it with self test if it comes then this is the problem with thr pr driver,if it doesn't give the test page then the issue with the formatter,first try with step one then 2nd ur problem will resolve.......................
1. Tap (the back arrow) or (the forward arrow) (depending on the app you're using), then tap Print.
2. Tap Select Printer to select a printer.
3. Set printer options, such as number of copies and double-sided output (if the printer supports it). Some apps also let you set a range of pages to print.
4. Tap Print.
