Question about DISH Network 54 1 Ir Vip 622 722 Dvr Remote 222
Unlock all channels on ecostart vip 722k
Unlock all channels
Posted by Melia Michelle... on
1 Related Answer
TommyF DISH
dish
  • 263 Answers
Delivering video anywhere, anytime.
    Verified Fixya Pro
    SOURCE: the hum from my vip
    pwgasson,
    Some noise from the receivers is normal as they are constantly updating the guide and checking for any software updates. How loud would you say the hum is, and is it constant or intermittent?
    Tommy Faust
    DISH Network
    Posted on Jul 22, 2011
    I need a remote code for my dish network VIP722k DVR with my sony RMVZ320 remote
    Check with DiSH for a possibly unpublished code. You may find that only the DiSH remote will work.
    Jan 01, 2014 | DISH Network IR Remote Control
    Is this resiver HD ?
    am_witek,
    Our 625 receiver is not an HD model. Our current HD models are ViP 211/211k, 222, 612, 622, 722/722k, 922, and our Hopper receiver.
    If you have any other questions, let me know!
    Tommy Faust
    DISH Social Media Representative
    Nov 24, 2012 | DISH Network DVR-625 DTV Receiver /...
    The hum from my vip 722k dvr box keeps me awake at night. thank you!!
    pwgasson,
    Tommy Faust
    DISH Network
    Jul 20, 2011 | DISH Network DVR-625 DTV Receiver /...
    Llomy id is blocked help me to unlock
    Checking virtual IP servers...
    [VIP Raw] Resolving host name vcs1.msg.yahoo.com... [PASSED]
    [VIP Raw] Connecting to Virtual IP server 98.136.48.32... [FAILED]
     ***  'COMPONENT_TYPE_WININET' value: '12029' ***
    [VIP Raw] Resolving host name vcs2.msg.yahoo.com... [PASSED]
    [VIP Raw] Connecting to Virtual IP server 67.195.186.241... [FAILED]
    [VIP Raw] Resolving host name 98.136.48.100... [PASSED]
    [VIP Raw] Connecting to Virtual IP server 98.136.48.100... [FAILED]
    [VIP Raw] Resolving host name 98.136.48.110... [PASSED]
    [VIP Raw] Connecting to Virtual IP server 98.136.48.110... [FAILED]
    [VIP Raw] Resolving host name 67.195.187.228... [PASSED]
    [VIP Raw] Connecting to Virtual IP server 67.195.187.228... [FAILED]
    [VIP Raw] Resolving host name 67.195.187.229... [PASSED]
    [VIP Raw] Connecting to Virtual IP server 67.195.187.229... [FAILED]
    [VIP Raw] FAILED
     ***  'COMPONENT_TYPE_YCP' YCPError: 'YMSG.ColoSelectionFailed' ***
    Checking HTTP virtual IP servers...
    [VIP Http] Resolving host name httpvcs1.msg.yahoo.com... [PASSED]
    [VIP Http] Connecting to HTTP Virtual IP server 98.136.48.229... [FAILED]
    [VIP Http] Resolving host name httpvcs2.msg.yahoo.com... [PASSED]
    [VIP Http] Connecting to HTTP Virtual IP server 98.139.61.47... [FAILED]
    [VIP Http] Resolving host name 216.155.194.137... [PASSED]
    [VIP Http] Connecting to HTTP Virtual IP server 216.155.194.137... [FAILED]
    [VIP Http] Resolving host name 98.136.112.142... [PASSED]
    [VIP Http] Connecting to HTTP Virtual IP server 98.136.112.142... [FAILED]
    [VIP Http] FAILED
    Apr 19, 2011 | Yahoo Messenger
    I just switched to an HD receiver. The sound on the HD Channels is lower than the sound on the regular channels. How can I fix this? Dishnetwork has aready checked their end.
    Some Sanyo TV's have a feature called Dynamic volume, this feature can be enabled by just pressing the dynamic volume button on the factory remote. We happen to offer a similar feature called volume leveling on our VIP 722k, 612, and 222k receivers. This is a recently released feature that will keep the volume even, during commercials or when changing channels. To access this press menu 6-1-6 and select enable under volume leveling.
    Daniel Busa
    DISH Network
    Customer Service
    Oct 03, 2010 | Sanyo DP37647 37 in. LCD TV
    Dish vip 622 and vip 722k frequent picture freeze and restart
    Sounds like a signal strength issue. You may have either a low signal or something like a tree limb is blowing into the signal path dropping the signal strength to a point low enough to causes issues.
    Apr 13, 2010 | Televison & Video
    I am trying to hook up my Philips 19PR19 (made in 1998) tv to the dish network receiver, it has 3 prongs diff. colors attached and the cable cord is already to go in the wall...I don't see anywhere on the...
    Because your TV is an older one, it might not have, what they call RCA inputs (the 3 colored cable) Red-audio right, White-audio left, Yellow-video. If I understand you.
    You do have the option of using the 75-ohm coaxial cable inputs. Signal comes in from outside to the 722k, Output of the 722k to the 75ohm coax input on the back of the TV. Tune your TV to ch. 3 or 4. Make sure the switch on the back of the 722k is set to the same.
    If you really want to use the RCA colored cables, then you need to buy an RF modulator, which integrates older tv's to newer products. But usually dvd players, not necessarily cable boxes, but it would work if hooked up correctly.
    You plug the RCA red, white and yellow from the 722k, into the rf modulator, choose channel 3 or 4 on the modulator
    Connect 75ohm coax cable from rf modulator to TV 75ohm coax cable input. Choose channel 3 or 4 on the TV.
    Hope this helps.
    Apr 07, 2010 | Philips 19PR19 19" TV
    CANT GET ON LINE
    The ethernet port is not active on these receivers thus not allowing you to get on ine. There currently are no plans to activate this in the future but you may for an upgrade to a 722 which does allow this and is HD capable and has 300 hours of SD record tine available. Thanks for using Fix Ya.
    Feb 14, 2010 | DISH Network DVR-625 DTV Receiver /...
    Sounds stop working after about 1 to 2 hours of viewing.
    We would be happy to help you with this. The volume levelingfeature that we have sounds perfect for this situation; it keeps the volumelevels consistent between programming and commercials and also prevents drasticvolume level changes when switching between HD and SD programming. The volumeleveling feature is supported by the following receivers: ViP 222k, ViP 612,ViP 722k, and ViP 922; the model number of your receiver is displayed onthe front in the lower left corner. Your receiver needs to be connected by onof the following: composite cable (green, blue, red cables), coax cable (singlecable with metallic tip), HDMI or optical devices that do not support Dolbyaudio.
    Start by pressing the menu button on your DISH Network remote control, thenpress the number 6 for system setup then 7 for audio output. Once therehighlight the "Enable" option below Volume Leveling and press select.Once enable exit the menu by selecting done on the right side of the screen.
    We hope this helps to get things set up the way you like it. Thanks forchoosing DISH Network!
    Phillip Chang
    DISH Network Customer Service Representative
    Jan 17, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
    Need to Frequently Reset Dish Network HD VIP 612 Solo DVR.
    When you bring up your guide look at the top of the screen and you will see the LIST: if this says ALL HD then press the guide button until you see ALL SUB or a menu and select ALL SUB. If your guide keeps changing by itself its possible to have remote interfence since you have a UHF remote, especially if you also see channel changes as well. Try setting the guide and go from there. If you still continue to have issues call 1-800-333-3474 for tech support for extensive troubleshooting or at dishnetwork .com/tech.
    Dec 01, 2009 | DISH Network ViP 612
    DISH Network 54 1 Ir Vip 622 722 Dvr Remote 222 Logo
    138 people viewed this question
    Top DISH Network Home Security Experts
    Marvin
    Marvin
    Tom Chichester
    Are you a DISH Network Home Security Expert? Answer questions, earn points and help others
