Question about Altec Lansing VS2121 Computer Speakers
Altec lansing fmw - Altec Lansing VS2121 Computer Speakers
5 Suggested Answers
Open SKy
Carlos L. Burgos
  • 620 Answers
SOURCE: one drive for Altec Lansing Technologies Inc. 'ACS-295' dell
Hello there
What kind of help on specific device from altec you need?
be more specific
Posted on Nov 29, 2007
Anonymous
  • 4 Answers
SOURCE: how to repair atp3 altec lansing
Best bet would be to just strip the wire with a wire stripper or utility knife and twist the bare ends together to fix the connection. A little electrical tape around those wires and you should be almost good as new. Of course you might notice some difference in quality but I'm pretty sure the only way round that would be replacing the cable.
Try it out and let me know how it works out for you. If you know how to solder it might be a good idea to solder the connection as well.
Posted on Jan 05, 2008
Anonymous
SOURCE: Finding replacement Power Supply for Altec Lansing
I did the same! Thanks for suggesting a call to Customer Support (800)258+3288. The guy didn't seem overly pleased to help, but he did promise to send me a new power supply. Also, he said that they don't make the iM7 anymore, but I had already found out that the iM9 uses the same power supply. I, too, will wait and see.
Posted on Jul 07, 2008
Anonymous
SOURCE: Altec Lansing ada745 fuse
Yes, it's a 1A 250V glass fuse, 0.75" (1.9cm) long. The only other number on the fuse is "239", if that means anything. You take it out by putting a flat screwdriver in the slot on the fuse holder cap, turn counter-clockwise, and pull out once it releases.
Posted on Nov 20, 2008
Anonymous
  • 57 Answers
SOURCE: I have Altec Lansing AVS 300 multimedia speakers with no power
Unfortunately the subwoofer supplies the power to the amp on the speakers, Once again I have the solution,
These speakers are factory molded so that the only way to open them is to break the factory seal
this can be done by sharply rapping the seam at the bottom of the speaker with a heavy screwdriver handle or something similar.
Now you need to supply power to the amp...If you do not have the subwoofer you will need a 4.5volt power supply, after removing the board from the casing find the red white and black wires connecting
the orange plug wire to it, Personally I removed the entire cord from the unit, shough you can splice in at this point if you desire.
Connect the white lead to your posative on your power supply by either splicing or soldering, connect the ground to the heat sink using the screw that is already there holding the chip to the sink. reassemble the speaker.....super glue... and you are now in business.
Ed Meyer
Owner AACS
www.alwaysaffordablesolutions.com
Posted on May 22, 2009
Disassemble Altec Lansing T612
The front of the Alec Lansing t612 got smudged with glue. How doiremovetkhespeakercover so I can clean the cover
Dec 06, 2011 | Altec Lansing T612 Remote Control Speaker...
Ac adapter for altec lansing model#acs40 voltage,current & polarity
Altec Lansing Model Number A 1664
Output 15 volts DC 800ma
center Positive +
Jul 29, 2010 | Altec Lansing Multimedia Computer Speakers
Need advice on Altec Lansing x5021
Altec Lansing is the best company to buy speakers if you watch movies or listen to music. it hits both deep and a strong bass. These are the best speakers to buy.
Feb 25, 2010 | Altec Lansing MX5021 System
Lost cord!
I have them for sale AC Adapter For Altec Lansing speakers inMotion iM600.Price is $15.95 Plus $6.95 shipping . send me your email and address to this email [email protected] and I will invoice you through paypal. Thanks
Mar 25, 2009 | Altec Lansing Inmotion-IM600...
One drive for Altec Lansing Technologies Inc. 'ACS-295' dell
Hello there
be more specific
Nov 28, 2007 | Altec Lansing ACS 295 Computer Speakers
Altec lansing
I had the same problem. After numerous calls to Altec Lansing they sent me out a new one. The new one doesn't have the same connector on it. I called tech support only to hear that they discontinued the 621 and don't make parts for it. Sorry, you are probably out of luck.
Oct 26, 2007 | Altec Lansing 621 Computer Speakers
Altec Lansing VS2121 Computer Speakers Logo
172 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Sharps s
Ekse
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
