I want to install bake unit
SOURCE: Install bake unit in GE wall oven model JKP07J
I honestly believe you are right. you should be able to wiggle it back and forth and pull it out.
SOURCE: I have lost the manual for our B1601D - Built-In
either will work, fan bake will give you a more even cooking though
SOURCE: how connected
You can connect it either way. However I would recommend either split-bolt connectors or ring lugs w/ bolt and nuts rather than wire nuts, if you choose to hard wire it.
SOURCE: Ge Profile built-in 27 inch wall oven -- When I
f9 means your control panel needs to be replaced..chances are part is not covered and if it is the only way you can obtain it is through having service
SOURCE: 665.95802000 f1 - E 1 error code
take the consol off you will find the tech sheet with all the codes. make sure you turn your power off first.
