Question about Insignia 32" 720p Flat-Panel LCD HDTV
My Insignia 32" LED TV will not turn on with the remote. Even the Comcast cable remote will not turn it on. It will do volume. The Comcast will only do channels.
Posted by Ben Masullo on
vkcamacho16
    New Friend:
When i turn on my flat panel tv the light turn on but the tv don,t come on.
Posted on Feb 05, 2013
2 Related Answers
coyotedave
  • 280 Answers
SOURCE: cannot turn tv off with power button or remote , must unplugpower
It could be a stuck button on the set. check to make sure they all feel the same.. If one don't feel right try to free it .. If a button is stuck it wont let any of the others work or the remote.
Posted on May 01, 2009
John-INSG
John-INSG
  • 312 Answers
SOURCE: I have a 32 in insignia and a universal remote was
Turn your TV off and unplug it for several minutes. Remove the batteries from any remote controls that you use for the TV, press all of their buttons, and install fresh batteries. Reset the TV to factory defaults. The universal remote control should not have caused any damage to the TV. If the problem persists, we recommend that you seek service by calling 1-888-237-8289 in the U.S or 1-866-237-8289 in Canada.
Posted on Jul 02, 2010
Volume decreases by itself
maybe defective speaker or audio output ic or shorted capacitor within audio circuit
Nov 09, 2008 | RCA F32648 32" TV
DPI
The owner's guide for the IS-LCDTV32 is here: http://www.insignia-products.com/t-user_manuals.aspx bottom of the page and be patient it's a slow loader..
As for the comcast remote code you can look that up at: http://www.remotecodelist.com/remotes/
Follow down to the model comcast remote that you have and click on the link for the codes.
Good Luck!
Bill
Apr 06, 2008 | Insignia IS-LCDTV32 32 in. Television
Code to remote
try the code for a "sansui" brand, it worked for my tv
Jan 22, 2008 | Insignia IS-LCDTV32 32 in. Television
Code for Vizio tv
I contacted Vizio the other day. They tell me that they use the same generic codes as LG. I have Suddenlink Cable, formerly Charter, so I still use the Charter remote. My remote only needed 3 digits and I have noticed that many need 4 or 5. I can tell you that the LG code worked for my tv. I can power on/off, volume, and change the channel. All other functions require the manufacture's remote. The code I used is 005. There was also 004 but that did not work on my tv. Hope this helps someone!
Dec 26, 2007 | Vizio L32 32 in. LCD HDTV
Remote
Insignia finally has a remote code finder on their website!!
http://www.insignia-products.com/universalcontrolcodes.aspx
Nov 23, 2007 | Insignia IS-LCDTV32 32 in. Television
Remote control code needed for this TV
Need to program my Insignia TV to my Direct TV remote. Need code
Nov 07, 2007 | Insignia IS 20" TV040919 TV
Insignia 32 inch LCD TV: Can not change Channel or Volume !
I have one in my shop with the same problem. Power is the only function that works. I repaired the power supply six monts ago. Now it looks like a bad digital processor board which is non-repairable. I can't believe what's happened to the tv business. Absolutely disgusting!
Oct 12, 2007 | Insignia IS-LCDTV32 32 in. Television
Insignia 32" 720p Flat-Panel LCD HDTV Logo
644 people viewed this question
Top Insignia Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
