Question about Patton Electric Patton PUH680-U Electric Utility Heater 1500-Watt
When I turn on the heater it turn back off
When I turn on the heater it take 1 minute long to turn back off a light pop out then it turn back off
Posted by zarate_pedro on
How turn on pilot on teledyne laars series 2
turn gas valve to pilot hold down for 1 minute keep holdibg and light pilot hold for 2 minutes then turn to on
May 27, 2014 | Teledyne Laars Laars Lite 2 Pool Heater...
Popcorn machine model tpc-603 manual
Treat Time Model TPC-603
Turn on light and popcorn buttons, for 2 minutes to heat up the popper's kettle.
Then turn off the popcorn button, this stops the turning gears while loading oil and popping corn.
Warning the stainless steel kettle will be hot. Might want to wear an oven mitt.
1 tablespoon of oil (I use coconut oil) and 1/3 cup of popping corn. This makes est. 6 to 8 cups of popcorn.
NOW turn on the popcorn button so the gears start turning, this turns a wire on the bottom inside the kettle to keep the kernels from sticking or burning to the bottom.
If making multi batches, during the process it states in the manual to allow it to cool 5 to 10 minutes. I normally pop 3 to 4 batches and then let it cool down.
When finished popping, turn off both the light and popcorn buttons.
Dec 28, 2012 | Kitchen Appliances - Others
R=8 128 Code on Pentair Mastertemp Heater what does it mean?
check manual bypass possible overheating or running out of gas
Apr 10, 2012 | Pentair Mastertemp Heater
How do i relight my water heater
turn gas knob to off, wait a minute, then turn knob to pilot. then press down on knob while lighting pilot, hold down at least 1 minute, then let the knob up slow. if it lights, then turn knob to run. if you can not light it after a few trys then the thermal coupling is bad and needs replaced. have a good day !
May 01, 2011 | Rinnai Orbis Vented Heater 15,000 BTU Wall...
I have a cs1205 electralog heater. after 5 minutes we hear a pop and the heater stops working. we shut it off and will hear a pop then turn it back on. it will work again for about 5 minutes. what is wrong...
I have an electralog cs1205, when i turn it on, although it works , after about 10 seconds it makes a strange noise. It never did this before. Any ideas on whats wrong?
Nov 27, 2010 | Dimplex Compact Electric Flame Stove...
Heater turns on and heats 2-3 degress then the service heater light comes on.After about 1 minute the heater fires back up and the light goes out and it repeats this cycle until it up to set temp.
Your "bypass valve" may be wide open, which causes the heater to overheat and shut down till it cools off. Just after the filter there is a pipe, then a valve, then another pipe.Close the valve at least 1/2 way (if not more). This will force water through the heater and keep it from overheating.
Oct 28, 2010 | Sta Rite Pool & Spa
After a few minutes of burner heating the water, gas shuts off.
A couple of things to check:
If possible, remove the pilot gas assembly and clean the gas jet and thermocouple - they can get carboned up and stop working properly. Make sure the pilot flame and deflector is aimed properly and making the thermocouple glow red hot. If the problem persists, you may want to replace the thermocouple and also check the propane regulator.
Apr 20, 2009 | RTO Atwood Water Heater - 6 Gal LP
Heater turns itself off after 2 minutes.
there might be timer setting or there coil is faulty.check it.
Jan 14, 2009 | Honeywell HZ-3220BW Compact Heater
Patton Electric Patton PUH680-U Electric Utility Heater 1500-Watt Logo
29 people viewed this question
Top Patton Electric Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Are you a Patton Electric Heating and Cooling Expert? Answer questions, earn points and help others
