This happens for every record I play how do i straighten out the record?
If it is warped then you could really be out of luck unfortunately, but it could just need a clean - I've included a link to a full guide on how you can clean records either manually or with a cleaner. How to Clean Vinyl Records Our Complete Guide Record Players Hub
The only thing you can do is clean the record with cleaning fluid. You will find special cleaning fluids for records on Amazon. If the record is warped you can try a weight pressing down on the record. But sadly if a record is warped bad there's no real cure.
SOURCE: Crosley Record Player Stopped Spinning...
I had this same problem with my Crosley 704 and it bamboozled me to no end.
After digging around I dug up the manual online (I bought mine used so I didn't have one to consult). It turns out the record stops when it gets to the end, and to get it spinning again you have to lift up the tone arm and move it right (past the holding latch) until it clicks, and voila, it starts spinning again, ready for a new record.
You'd think that they coulda made it more obvious :(
SOURCE: Hi. I have a Crosley CR40
It sounds like you have too much pressure on the tone arm. Check the underside for springs. You might be able to remedy the problem the old fashioned way. Tape a coin onto the top of the tone arm, as far to the rear as possible. This will eliminate some of the downward pressure onto the record.
