SOURCE: My miele g886 dishwasher intake/drain light keeps
the inlet/drain light is a standard fault light and can mean anything without connecting the Miele dianostic software to the unit. This is only available to Miele service techs or service agents. If the light comes on in the first minute then it is probably a drain fault. Try checking the drain spigot at the sink end where the drain hose connects as these are usually the cause of most dishwasher faults.Hope this helps
SOURCE: fault code f70, drain pump keeps running, nothing else works
Yes. F70 is a flood in the base of the unit which activates the float switch and constantly activates the drain pump until the water has gone. Isolate the unit at the power switch and remove the bottom panel under the door panel. Dry up the water as best possible with a towel. You will see the float at the front. Run the unit again and check for any water leaks. You may just have over sudded the unit with too much detergent. Only use 2 teaspoons of powder. To start with while testing don't use any detergent. Good luck
Hope this helps.
SOURCE: Drain pump goes ON when ON-OFF button is pressed,
Seems that the drain pump circuit in the main program controller unit power and keeps on as there is no logic feedback to cut off the power. It can be that the drain is clogged and so the water level detect keeps sensing due to a fault. check the sensors , check the drain filters , check the machine LEVEL so that the water drains clearly to the drain pump.
SOURCE: F70 plus not draining completely
check for obstructions in the pump, the hose and the drain.
