They have a 7'30 degree view and have a nuber on the front that reads 54A4 24896 and very similar to the Fujinon Polaris FMT-SX
SOURCE: Ranging reticle in Fujinon FMTRC-SX Binocular
Its easier to explain seeing a diagram. Go to Tascos website and download the instruction manual for the Offshore binoculars or Steiner Optic website and download the general binoculars instruction manual. It has all of Steiners models incuding those with a reticle. Most reticles are the same and there is no difference between meters and yards as your calculations are an approximate.
If your Fujinon is an ex military unit it has what is known as an M22 reticle. It is only slighlty different as it is graduated in mils but the calculations is the same. If it is the M22, google Binocular M22 manual. The military number for this is TM 9-1240-403-12 & P
SOURCE: Fujinon Technostabi 14x40--battery
I had this problem a couple of years ago. I bought a new battery compartment from Fujinon's US repair center: http://www.bakermarineusa.com. It was about $38. Unfortunately I now have the same problem with the new battery compartment. I'd like to find a source of the metal spring clips.
SOURCE: Fujinon-Mariner WPC-XL Lens Cap replacement
You can order a replacement set at: http://www.bakermarineusa.com/index.php?id=17&cat=38&prod=137
SOURCE: 7x50 Marine binoclars, Fujinon w/compass.
I've been thinking about this for awhile, and it seems to me you're experiencing a factory defect. I don't have one of these devices, or I'd know what "normal" was for compass, but if you can't easily have the display centered, something is out of kilter. Was it always like this, or did it just start occurring recenty? Your best venue would be to contact Fujinon support and see if they will replace or fix the problem. Here is their site:
http://www.fujinon.com/NewsAndEvents/PressReleases/pr.aspx?id=84
Good luck, and hope this helps.
SOURCE: I use Fujinon Mariner 7x50
Dont Quote me in any manual anywhere but, I would try 45 degree's
Hope this helps
