Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
My Whirlpool Ultimate Care II Washer doesn't stop filling with water
Posted by Ron Olsonn on
steve
  • Whirlpool Master
  • 3,361 Answers
If this only happens when the machine is turned on,the tube from the tub to the water level switch is pinched or broken. If the clear plastic tube is not pinched or broken,the water level switch in the control console is bad. If the machine lets water through when it is in the OFF position,the water valve where the hoses connect are bad.
Posted on Jan 02, 2013
  • Jorge Rendon
    Jorge Rendon Jun 19, 2015
    try this Washer fills with water and overflows:
    The water pressure level switch is a pressure activated switch that is used to determine the correct water level in the tub. This part is normally located behind the control panel and will have a hose or air dome tube that connects it to the tub. On washers that use an electronic control, this switch may be located at the sump area below the tub. As the water fills in the tub it will compress the air in the tube and push against a diaphragm inside the switch. The switch will control the water inlet valve and turn the valve off at the correct water level. If the tube has a leak, not enough pressure may be created to activate the switch and the washer may overfill. If the switch is defective it may also cause the machine to overfill. To determine if the switch is bad, you should first eliminate the air dome hose as a problem. Look for signs of cracks or worn areas on the hose. Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well. If the air dome hose appears to be ok, then the water level switch may be defective.
    You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube.
    If the machine starts to wash. the pressure switch is more than likely good
    ( No wash- then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED).
    The other item to check would be your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board. You can also do a live volt test to see if it is getting the full 120 current, but be sure to unplug unit before testing as this is a live test.
    Also another trick to check the water valve, is to first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don’t have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed
    By the way my advice is free cuz God is good!
5 Related Answers
Anonymous
  • 116 Answers
SOURCE: whirlpool ultimate care II stops after filling
Hi, could be faulty timer, faulty water level switch, faulty start capacitor for motor, or faulty motor. always put clothes in machine before starting. you can empty machine by lowering drain hose to flow level.
Posted on Aug 02, 2009
mikedurland
Mike Durland
  • 481 Answers
SOURCE: Whirlpool Ultimate Care II Plus Washer Model: LSQ9264HZ0
if you hear the motor running while it is supposed to be agitating or spinning then it is most likely the direct drive coupling between the motor and transmission.43f18ab.jpg9bd1c44.jpg if you already checked this and think it is a different problem then let me know, i will help you figure it out.  Mike
Posted on Jul 15, 2008
Cary Crook
  • 105 Answers
SOURCE: fills up with water and wont stop
Bad Preasure valve comes to mind first and formost it acts like a level sensor balanceing the size indicated for fill.
Posted on Feb 10, 2009
honeymokey
honeymokey
  • 3113 Answers
SOURCE: Whirlpool Ultimate Care II washer fills with water and stops
Lid switch. Push down on lid.
Posted on Jun 18, 2009
washdryman
ROB CHRISTIAN
  • 154 Answers
SOURCE: My whirlpool ultimate care II washer will fill but
BAD LID CONTROL SWITCH
Posted on Feb 07, 2010
I have a whirlpool ultimate care II washer. It stopped in the middle of a load, full of water, and now it won't do anything. It won't drain, fill, move, or make any noises.
You will need to check the capacitor on the machine. It can be tested with a capacitance meter the easiest. It can be tested with a resistance meter, but this will tell you if the capacitor is shorted or open. It will not tell you the capacitive value if the component has drifted out of tolerance. You put the meter across the terminals and watch the display for counting up to infinity. This will occur quickly and disappear very quickly. Now reverse the leads on the terminals, (reverse the polarity). The same thing should happen, but a bit more pronounced. It will once again rise very quickly and go to an infinite reading. This tells you that the capacitor isn't shorted or open internally. Here is the capacitor to order if you should find it bad.
Nov 28, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
No spin and water not goes
if the washer fills with water and then doesn't run check the lid switch part number 8054980 and it's around 22 dollars,watch video http://www.youtube.com/watch?v=MFsvLiuTniU
Jan 06, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer will pour water but will not fill up
I see it looks like you have the 3 level water height on the panel. Usually labeled mini, Normal, Large loads. Try selecting Large load.
If that doesn't work, the switch is bad or the fill stop air chamber is not working.
Jun 26, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate care II stops after filling
Aug 02, 2009 | Whirlpool Ultimate Care II GSW9650LW Top...
Fills up with water and wont stop
Feb 10, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Yes if its filling slow do to a blockage in a screened hose it will .If it never stops filling and doesnt over flow than its syphoning the water and you need to elevate thr drain hose higher than the water level and it will kick into wash. Please rate This !!
Jul 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
627 people viewed this question
Marvin
Marvin
Michael Thomas
Michael Thomas
