HP LaserJet M1005 All-In-One Printer Logo
Anonymous Posted on Dec 27, 2012
Unable to scan hp laser jet m1005 mfp from mac book pro
mukhtar21 shaikh
Level 3:
President:
  • HP Master 2,022 Answers
  • Posted on Dec 27, 2012
mukhtar21 shaikh
HP Master
Level 3:
President:
Answers
2022
Questions
Helped
668882
Points
5817
Make sure the cale is connected properly.
  • Anonymous Dec 27, 2012
    i can print but i didn't find any icon for scanner download software from hp support
5 Related Answers
Subhankar Ghosh
  • 180 Answers
  • Posted on Nov 01, 2010
SOURCE: sir my hp laser jet
Hi
You can get the drivers from HERE.
Just select the Operating System and the Langauge which ever you want and you can download the drivers.
All the Best.
With Regards:-
Subhankar Ghosh
Anonymous
  • 255 Answers
  • Posted on Jul 04, 2009
SOURCE: scanner error 12
uninstall the software of scanner and reinstall it
check your cables for loose contacts
Anonymous
  • Posted on Oct 28, 2010
SOURCE: How do i refill my HP M1005 MFP Laser Printer toner cartridge?
if any softwere is have you for chaquing my cartage how many days are left to changing thel me
Anonymous
  • 8 Answers
  • Posted on Nov 23, 2010
SOURCE: Printer Model : HP Laser
indicate that the scanner unit are error.reseat the flexible cable in the scanner unit.
Anonymous
  • 83 Answers
  • Posted on Feb 18, 2011
SOURCE: I CANT FIND DRIVE FOR
Hello!
First you need to open this link - http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=1839459&lang=en&cc=in&prodTypeId=18972&prodSeriesId=1839458&taskId=135
- To HP's website. After that you should choose an operating system (by clicking on the link that states your operating system). Let's say you're using Windows 7, so you choose Microsoft Windows 7 (32-bit) (meaning, press on that link). In the web page that opens next, you should scroll down, until you get to the Driver table. Then, you should press the "Download" button. That will open a dialog box, in which you can choose to "Save" or "Open" (or cancel). I advise you to Save or Download the file to your hard drive.
Hopes that helps, good luck!
1helpful
3answers
Loss my drivers for HP Laserjet M1005 mfp
If you go to H.P's website and go to support imput that you need drivers for your laserjet m1005 mfp. and you will either be able to down load it right away or they will send you an e-mail with it or a link to retrieve one..Good Luck
2answers
Scanner 12 error
HP LaserJet M1005 mfp is not work properly. printer show scanner error 12 ple. solution
1helpful
Hp laser jet m1005 mfp scanner error 12 problem print ok
hi
1. check for driver update
if not resolv
2. Firmware Update
if not
3. the motor of the scaner is damage
2answers
Scanner error 12 on hp laserjet m1005
When the lid or door of an HP Laser Jet printer isn't properly closed, the printer's display will read "Error 12." You can usually correct an "Error 12" by closing the printer's door securely -- a process which may require that you first fix the orientation of a toner cartridge so that the door can close. In some instances, an "Error 12" appears due to some other issue, such as a missing toner cartridge or a defective paper-feeding component.
Sir my hp laser jet M1005 MFP printer driver give me plz
Hi
All the Best.
With Regards:-
Subhankar Ghosh
6helpful
3answers
Scanner error 12
Unable to print or scan - copy only
that is a networking problem the fact the you can copy eliminates the possibility that there is something wrong with the printer / copier
k24674
Grand Canyon Tech
Grand Canyon Tech
