Question about Mercedes-Benz Vehicle Parts & Accessories
2006 Mercedes-Benz C230, the starter turns very slowly.
When I turn the key to start, the starter turns the engine very, very slowly. It is turning, but not at the rate to start it. The battery voltage is at 12.8 volts.
Posted by Vance Herrin on
Christian Krentz
  • Mercedes-Benz Master
  • 694 Answers
The batt voltage is to low try jumping it with jumper cables if it starts you need a battery
Posted on Mar 02, 2014
1 Related Answer
chris brown
  • 99 Answers
SOURCE: Started in the morning only with a boost.Sat all
yes the battery is probably five years old and not capable of holding a charge. if you go to a Murray's or autozone they will test the battery for free.
Posted on Jan 22, 2011
Can the the smart key bad when it wont turn the ignition but still lock an unlock the doors
Yes it can. I have heard of smart keys having problems especially after getting wet. Any good locksmith can check and reprogram your key if necessary
Jul 21, 2014 | Mercedes C-class C230 C240 C350 C55...
M 2007 mercedes c230 will sometimes not start. When I turn the key it sticks in that position and trys to start but doesn't and I must turn the key off to make it stop. If I let it sit it will start...
Likely a bad ignition tumbler, considering the key "sticking" in the start position.
Best bet is to hit the dealer and ask one of their service advisors if they've run into this problem before.
Feb 10, 2014 | 2007 Mercedes-Benz C230 Sedan
Ignition key wont turn
Wrong Key? or Worn key wiggle it up an down when trying to turn it...
Jan 18, 2013 | Ignition System for Mercedes-Benz C230...
My 1999 c230 Mercedes Benz key won't start my car
Jerk the wheel back and forth while trying to turn the key
Nov 14, 2012 | Cars & Trucks
The key in the ignition to my mercedes 2002 c320 will not turn
Just replaced my key the ignition switch and the esl in my c230 98 Benz. Worked for about a week and now the esl will not unlock the steering or start the car. Is there any way to reset the esl? All three components are new I don't understand the problem .what causes the esl not to engage when you put the key in the ignition
Feb 22, 2012 | Mercedes-Benz C230 Cars & Trucks
I have a mercedes c230 kompressor that will not start, key will not turn, could it be the battery
If the key will not turn, the interlock mechanism is stopping it. Try to jiggle the transmission shifter (in Park) to see if that is keeping the key from turning. You can also try it in neutral.
Aug 29, 2010 | Mercedes-Benz C230 Cars & Trucks
I can not turn the key.
calla dealer as the key may be too severely worn and thus will not perform its duty
Apr 02, 2010 | 2007 Mercedes-Benz C230 Sedan
C230 Key Won`t Turn the car only went i use 14.3V
The starter is turning only when the solenoid close the contact to deliver the current to the starter . When this happens it then turns the bendix to engage with the flying wheel to start the engine.
The reason that you need higher voltage to have correct needed current going through the contact of the solenoid, hence the starter. The contact is corroded or rusty due to high spark at high current at every start time causing high resistance. V=IR the R resistance of the contact now is high so it need higher voltage (14.3 vs, 12.8 V) to deliver the same needed current for the starter.
Unfortunately, the solenoid is integrated with the starter, so you can not just replace the solenoid without replacing the starter.
If you can find the new battery holding at 14.3 V as you mentioned, then that is an economical solution since replacing the starter is costing more.
BTW where can I find the battery at 14.3V in case my friend's car has a same problem?
Jul 26, 2009 | Mercedes-Benz C230 Cars & Trucks
Reset alarm on 2000 Mercedes C230
Disconnect the battery lead at the starter motor.Leave off for a few hours then reconnect it.It should reset it for you.
May 12, 2009 | 2000 Mercedes-Benz C-Class
Vehicle Parts & Accessories Logo
65 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Bill Boyd
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
