Your problem could be in the bios. Press the delete key repeatedly while booting up to enter the Bios Setup Utility and check these options : IDE Configuration - as shown in the manual at chapter 4 page 14
Onboard PCI IDE Operate Mode - Enhanced Mode Enhanced Mode Support On - S-ATA Configure S-ATA as RAID - no
and also
Boot device priority - as shown in the manual at chapter 4 page 33
set your Sata drive as the 1st boot device
For additional info, refer to the manual in the link above.
It was already in enhanced mode; this gives two extra options in the IDE menu; the drive did not appear. I connected annother brand SATA drive. This also did not work. So this is a problem on the interface on the board, the firmware or SATA diiferences with earlyer SATA disks. In fact no problem and no big gain if it worked because it would only be 150Mb/sec . I connected a normal IDE drive. Thanks for your attention.It was already in enhanced mode; this gives two extra options in the IDE menu; the drive did not appear. I connected annother brand SATA drive. This also did not work. So this is a problem on the interface on the board, the firmware or SATA diiferences with earlyer SATA disks. In fact no problem and no big gain if it worked because it would only be 150Mb/sec . I connected a normal IDE drive. Thanks for your attention.
You can't post conmments that contain an email address.
SATA HARD DRIVE - XP INSTALLATION The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Hello samanozy , Some older motherboards will not support a too wide HDD whatever the interface. Another point is to know if you have set the boot priorities in the BIOS . Your machine is maybe attempting to boot from the Sata drive . Best regards , fanaudi .
get to the bios boot section
( on starting the computer hold down the delete key until the bios screen shows
in that section you will see boot preference
organize the sequence that the unit will boot from save and esc
so sata hard drive =1
cd=2
external hard dive =3 etc
You're Intel motherboard does support up to 4 SATA hard disk drives including SATA CD-ROM / DVD-ROM drive, reader/writers. This MB also includes two serial ATA IDE ports. The most likely reason you're system is not booting is because all SATA ports are all seen as Master drives. By connecting the SATA DVD-ROM drive the bios auto configured the SATA ports. You'll need to enter the bios when you're system boots-up. Press the F2 key on you're keyboard right after hearing a single beep. You will than enter the bios main menu. Listed at the main menu are devices connect to the motherboard. (Instruction on how to move around in the bios is listed at the bottom of the screen). Mainly, the hard disk drive or (drives) and the SATA DVD writer. You'll need to open the Boot tab. Look for boot order. You want the boot order set like so; First boot device: [Floppy disk] drive; if one is connected. Second Boot device: [Primary Hard Disk] drive. (The drive with windows installed on it). (This drive may be ATA IDE or SATA; you did not provide that information). Third Boot device: [DVD-Rom] drive. Save and exit the bios. The system will auto restart. You're windows operating system should load correctly after the auto re-start. The SATA data cable and the SATA power cable should be checked for good connection. It only takes a little bump to make either loose. Here is the link to Intel for you're motherboard; http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22+D102GGC2+%22
XP installation does not have SATA drivers.
You need to have the SATA driver on a floppy disk and during the XP installation press F6 to install the SATA driver.
The other alternative is to change the BIOS configuration and set the disk controller to IDE or SATA native driver, then install XP.
After Windows installation then install the SATA driver.
Download the driver from the motherboard WEB site.
Hi whistler1410, you need to enter your bios menu. Press the delete key every couple of seconds to load the bios menu.
Once in the bios (See instructions located at the bottom of the menu, to help you move about).
You should see all connected drives at the main menu.
This includes the SATA writer & hard disk drives.
Go to the bios menu, BOOT.
SATA drive even DVD drives are seen by the bios as a master drive. So within the BOOT menu go to "Boot device priority".
The boot priority should read as follows.
First boot device [Floppy disk drive] (If one is connected)
Second boot device [Your SATA DVD writer]
Third boot device [Your primary hard disk drive] (The drive with windows loaded on it).
If you do not have a floppy disk drive than make the first boot device your DVD writer.
Save the bios & exit the bios. You should not receive "boot disk error message anymore".
Run into a problem, post here.
Good luck whistler1410!
Mike
The sata cable\bus that connect the hard disk with the motherboard get loosen up some times.
that results in the disk boot failure.
if you once remove the sata cable from the harddisk and motherboard and then fix it tightly you can get
the system working properly again.
if the problem again persist then bye a new sata cable and fix it by replacing the older one,
Thank You!
Hi Grumpy
It sounds like your mainboard is not set up to allow for a SATA boot drive.
Have a look in your bios and ensure the boot order is set to the SATA drive first
Then, make sure the SATA drive is formatted and has an operating system installed.
Alternatively, boot the system from a boot disk ( your XP or Vista disk will allow this) and check to see if the board can see the drive and can read the drive if it is already formatted.
If not, format it and install the O/S onto it and make sure you answer YES to the question " do you wish to boot from this drive?"
Both my systems use SATA drives and I only had a boot fault because the "pre-formatted drive" I bought was not formatted and formatting under windows during O/S installation solved this issue..
Sounds like you need your manufacturer's SATA drivers.
This problem exists a lot when installing Windows from scratch on SATA hard disks. When you start the installation, Windows prompts you to "load additional drivers". It's at this point you put a floppy disk with the SATA drivers in.
If your install is already working, but just stopped as you say... then you could hunt around the BIOS for a SATA "compatibility" mode, which will get you booting straight away. Install the SATA drivers and you can then put the drive back into normal operation instead of compatibility mode.
This is also the reason why your other hard disk with Windows can see the SATA disk and optical drive... it probably has the SATA drivers installed.
hi, you need not have to upgrade the BIOS,, set the SATA HD on the IDE channel in the BIOS, or what options r avilable for SATA controller, if it is set to RAID, you will need a raid utility to format the SATA, or it wont shoe in windows, let ,e know
