When im trying to connect to the internet, my modem has got a red light where it says ''internet''. Appereantly it means that it can't find an IP address. How do i fix this? I've tried to restart the modem, trying to unplug and plug back in the plug that gives the modem the internet. The light is on the very-right side of the panel.
I think incorrect physical connection between your router device and the PC.Because cable modem status light should be solid green.it indicates that your ADSL/cable modem has a good connection.
Recheck and correct the Ethernet connection between your PC and the router device.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
SOURCE: when i connect my router to my computer i have no internet
Try To Change the lan card and then connect the router
SOURCE: router won't broadcast
Use your computer's web-browser to connect to the web-server "inside" the router.
Check the 'WAN' settings -- they seem to be OK, since you have Internet access.
Check the 'Wireless' settings, or just rerun the Wireless Configuration Wizard, to rebuild your wireless network.
SOURCE: hi i ahve a zoom
u have to configure it to connect to the internet once again through ur default gateway and to look for that open a command line in windows and type ipconfig and u should see ur default gateway. then type that in ur browser and VOILA!
SOURCE: unable to connect to internet
If I understand your problem correctly, you are able to connect to the Internet when you hook the computer directly to the modem, but not when the router is connected to the modem.
If this is the case, then you need to do a power drain on the modem. Power cycling the modem is not enough to clear the NVRAM of the MAC address of your computer. You have to unplug the power cord of the modem for 15 to 20 minutes in order for the NVRAM to reset and allow the modem to recognize the MAC address of the router.
After the modem has been unplugged for 15 to 20 minutes, disconnect the power cable from the router and then connect router to the modem using the Ethernet cable.
Next with the router power cord still disconnected, plug in the power cord of the modem and allow the modem to sync to the network.
Once the modem is finished with its start-up, plug-in the power cord of the router and let it sync to the network.
After the modem has completed its start-up, it should now be connected to the internet.
Good Luck
SOURCE: red world globe lit up
hold the reset button on the back of the router for 10 seconds and the router should reset back to factory settings and you have to set it up again. Here's the manual though. bottom of page 62. instruction if you forgot password. But it works the same.
http://static.highspeedbackbone.net/pdf/D-Link-DIR-615-Manual.pdf
