Hardware & Accessories Logo
A
Anonymous Posted on Nov 20, 2017
How to set the defrost time for Paragon 8145-20 D-Frost-O-Matic Time control?
I have a Paragon 8145-20 defrost timer installed on my walk-in freezer and the ice is accumultated on the cooling fins. I noticed that it runs 11 minutes then stop 3.5 minutes. I don't think that 3.5 minutes is enough to defrost the ice. So i want to set the defrost time longer but I don't know how. Please help me.
1 Related Answer
Anonymous
  • Posted on Jun 17, 2009
SOURCE: Set defrost timer on Paragon Electric Defrost-O-Matic
the problem is not necessarily with the timer. it seems you have more than ample time and time allocations to perform a complete defrost. most walk ins should have roughly 25-40 minutes of defrost every 4 to 8 hours. if you defrost with a heating element, you may have a problem with the strength of the element,or the element may be pulled away from the coil. you could also have a problem with the defrost thermostat(allowing the defrost to terminate prematurely)
Wiring walk freezer
Copy following link to identify defrost timer.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
Add a comment and say which defrost timer you have, which voltage and phase the incoming line
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
2helpful
I have a Paragon 8145-20 D-Frost-O Matic installed in on my walk-in freezer. The ice is accumulated on the fins of the freezer. Now it run for 11 minutes then stop for 3.5 minutes. I think the stop time...
1) Copy following links:
http://waterheatertimer.org/images/8145-work-image.jpg
2) Typically the 8145-20 defrost cycle is time-initiated and starts when tripper pin located on outer part of dial passes the time-of-day point.
Defrost cycle terminates or ends when pressure or temperature switch activates. This is also called the cycle limit switch.
http://waterheatertimer.org/images/8145-20-wiring-600.jpg
3) So your situation sounds like the pressure or temperature switch is not working correctly.
4) The 8145 timer also has 'time termination' setting. This red tripper is located on inner part of dial.
Usually the 'time termination' is used as back-up system if the pressure or temperature switch fails so that defrost cycle will not continue melting everything in freezer.
5) To solve problem until pressure-temperature switch is replaced, you can disconnect wire on terminal X, and then set 'time termination' for correct length of time by experimenting.
How to wire a paragon defrost timer with liquid line solenoid valve t-stat electric heater for walk in freezer
page 20 in the heatcraft refrigeration manual shows how to interface a paragon defrost timer with the t-stat and evaporator coil.
1helpful
2answers
What is the part number for timmer control of the T49 two door freeze
is it a Refr. or a Freezer for mthe freezer you can use a paragon model 8141-00-oem D-frost-o-matic timer control................good luck
I'm looking for a control wiring diagram for this set up; The condenser is on the roof with a paragon 8145-20 in it. I want to control the defrost cycle of the walk in freezer that is downstairs. The...
Open following link to see wiring diagram and manual for Paragon defrost timers:
8145-20 is 240V time-initiated, pressure or temperature terminated, with back-up time termination.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
I am not professional at commercial refrigeration, and can't answer your question directly.
However, you can see 8145-20 240V defrost timer wiring diagrams and manuals on following link.
8145 timer is time initiated, and pressure/temperature terminated, with back-up time termination.
4helpful
3answers
If the air flow and temperature are not being compromised leave it alone. If there is a gradual build up of ice on the evaporator you may have a defrost element or defrost limit switch problem. Set the defrost duration duration to 45 minutes and see if that solves the icing problem. 4 defrost cycles a day should be enough to keep the icing problem at bay. 3 defrost cycles at night about 1 hour apart may also remedy the problem. Experiment until you find the right combination of defrost cycles for your freezer. Watch for any thawing of the product in the freezer and adjust accordingly.
Bills Refrigeration/Montana.
Top Paragon Hardware & Accessories Experts
john h
Are you a Paragon Hardware and Accessory Expert? Answer questions, earn points and help others
