Question about Delta Faucet Delta 467-SSSD-DST Palo Diamond Seal Kitchen Pull-Out or Out Faucet Brillia
How to repair a Model # 468-SD-DST dripping faucett
1 Related Answer
packrat1948
Paul Beyer
  • 528 Answers
SOURCE: Need a Delta faucet repair guidge - Model #
http://www.deltafaucet.com/customersupport/documentation/468-SSSD-DST.html?document=pd
This the best I could find
Posted on Mar 14, 2011
Faucet leak from under the handle
IF YOU REPLACED ALL NEW PARTS THEN I WOULD GUESS THAT IT IS NOT PUT BACK TOGETHER RIGHT SOME THING MAY BE JUST A BIT OUT OF PLACE INSIDE CAUSING IT NOT TO SEAL. TAKE APART AND PUT TOGETHER AGAIN MAKING CERTAIN THAT EVERY THING IS LINED UP RIGHT. IF STILL LEAKS I'D GET A NEW ONE.
Sep 05, 2014 | Delta 468-SD-DST Cicero Pullout Spray...
Model 468 white sewing machine,need the manual
http://www.sewingpartsonline.com/
if the link does not work the manual is at
Jun 09, 2012 | Sewing Machines
My bathroom sink faucet has a slow leak. I cannot determine the make or model number. It is a single handle, 11 years old. The cover for the set screw ( on the handle) is red and blue, like American...
delta also uses red and blue,, but its fine, remove the insert and take it to any home improvement store, they will be able to match up the sleeve, if its just a slight drip, you can just replace the bottom washer and faucett seat,, if its a single handle you may have to get the kit that includes the O rings to rebuild it,, be sure and get some plumbers grease when putting it back in,, especially lube the O rings as they usually give out first
Jul 23, 2011 | Plumbing
When open the faucett water comes from the shower head and faucett at the same time
Open the cover plate up at the faucett and replace the faucetts cartrage and rubbers, sound like somting in that region has parished
Hope that is the problem
Jul 19, 2010 | Moen & One Handle Tub & Shower Faucet
Faucett drips after shutoff
First shut main water off to house. Pull handle, there is a set screw on bottom side. It is a allen wrench. Now with chanel locks unscrew bonnet and pull cartridge, behind you will find 2 black washers with springs in them. This is what you need to replace to get dripping to stop.
Sep 26, 2009 | Delta & Leland& Tub & Shower Faucet
Program Code
DIRECTV Model D-10 00001, 00002
Hughes Network Systems (most models) 00749
Hughes Network Systems models GAEB0, GAEB0A, GCEB0, GCEB0A,
HBH-SA, and HAH-SA 01749
GE models GRD33G2A and GRD33G3A, GRD122GW 00566
Hitachi model HDS210R 00819
Mitsubishi HD models SRHD400 and SRHD500 00749
Panasonic models TZ-DBS01 and TZ-DRD100 00247
Panasonic models TUIRD10 and TUIRD20 00701
Philips models DSX5150R,DSX525R/I, DSX5350R, DSX5353R,
DSX5353X, and DSX5375R 01076
Philips models DSX5500 and DSX5400 00099
Proscan models PRD8630A and PRD8650B 00566
RCA models DRD102RW, DRD203RW, DRD301RA, DRD302RA,
DRD303RA, DRD403RA, DRD703RA, DRD502RB, DRD 503RB,
DRD505RB, DRD515RB, DRD523RB, and DRD705RB 00566
RCA models DRD202RD, DRD221RD, DRD222RD, DRD223RD
DRD225RD, DRD420RE, DRD440RE, DRD460RE, DRD480RE,
DRD430RG, DRD431RG, DRD450RG, DRD451RG, DRD485RG,
DRD486RG, DRD430RGA, DRD450RGA, DRD485RGA, DRD435RH,
DRD455RH, and DRD486RH 00392
Samsung model SIR-S60W 01109
Samsung models SIR-S70, SIR-S75, SIR-S300W, and SIR-S310W 01108
Sony models (All models except TiVo and Ultimate TV) 01639
Toshiba model TSR101DSS 00790
Uniden model UDS100 00724
Setup Codes for DIRECTV HD Receivers
DIRECTV Model H-10 00001, 00002
Hitachi model 61HDX98B 00819
HNS models HIRD-E8, HTL-HD 01750
LG model LSS-3200A, HTL-HD 01750
Mitsubishi model SR-HD5 01749, 00749
Philips model DSHD800R 01749
Proscan model PSHD105 00392
RCA models DTC-100, DTC-210 00392
Samsung model SIR-TS160 01276
Samsung models SIR-TS360 01609
Sony models SAT-HD100, 200,300 01639
Toshiba models DST-3000, DST-3100, DW65X91 01749, 01285
Zenith models DTV1080, HD-SAT520 01856
Setup Codes for DIRECTV DVRs
HNS models SD-DVR80, SD-DV40, SD-DVR120,
HDVR2, GXCEBOT, GXCEBOTD 01442
Philips models DSR704, DSR708, DSR6000,
DSR600R, DRS700/17 01142, 01442
RCA models DWD490RE, DWD496RG 01392
RCA models DVR39, 40, 80, 120 01442
Sony model SAT-T60 00639
Sony model SAT-W60 01640
Samsung models SIR-S4040R, SIR-S4080R, SIR-S4120R 01442
10
PROGRAMMING
Jan 26, 2008 | Directv RC23 Remote Control
Delta Faucet Delta 467-SSSD-DST Palo Diamond Seal Kitchen Pull-Out or Out Faucet Brillia Logo
310 people viewed this question
Top Delta Faucet Plumbing Experts
Muntejaya Ginting
Muntejaya Ginting
Bill Johnson
Marvin
Marvin
Are you a Delta Faucet Plumbing Expert? Answer questions, earn points and help others
