SOURCE: overheat reset switch for Sanyo PLC-Z4 projector
check the other questions on this topic, I just posted a detailed answer, and that was based on another's answer.
SOURCE: Sanyo Pro XtraX Remote Code
You may have reassigned the projector/remote control codes. If you still have your User's Manual, reference page 38 and there are instructions on how to reset the codes.
If you don't have the User Manual, it can be downloaded at http://sanyoservice.com/pdf/images/PLVZ4(OM5110749-00).pdf
Please let me know if you have any questions.
Good Luck!
SOURCE: plc-xu35
are the other top controls working like power, menu,select etc??
remote problems can be caused by inproper code settings in the setting menu items.
try to switch to " code 1 "
SOURCE: Sanyo PLV-70 Projector
check the safety switch under the lamp cover if the has snapped there wont be any power
SOURCE: I cannot get my remote to work with my Sanyo
I would first try changing the batteries in the remote and verifying that batteries are in the right direction (+ and - terminals line up).
Once that is done, try pointing the remote right at the infrared sensor at the front of the projector...the black plastic circle on the front of the projector.
