Question about Reddy Heater-30-55,000 BTU Variable
Tips on how to fix a Life Smart LS-500-1PC Infrared Heater
Heater will run for only a few minutes and then completely shut down.
Ben White
    New Friend:
  • 3 Answers
The above fix is NOT for a Life Smart LC-500-1PC.. this is Life Smart LC-500-1PC. http://lifesmartproducts.com/current-products/infrared-heaters/52-2011-products/332-ls-500-1pc.html
Sounds like the thermostat is out. Order one, and hope it comes with a repair manual!
Posted on Feb 21, 2013
  • matthew wardyn Dec 15, 2013
    Check the fan to see if it is moving, i have seen a few where the fan gets gummed up and the heater shuts down due to overheating
5 Related Answers
Therinnaiguy
Chandler Ede
  • 1420 Answers
SOURCE: Ready heater will run then shuts off
Change out the thermocouple.
Posted on Oct 21, 2008
tbugger
Jerry Magee
  • 232 Answers
SOURCE: heater shuts down prematurly
If the heater runs fine for the 15 or so minutes without smoke/odor- do this
  1. check for water droplets on bottom of tank
  2. check for restricted fuel filter
  3. test photocell
  4. test safety control (reset)
You don't state whether this is a spark plug heater *or* Hot Surface Ignitor type. I made the assumption you were inquirung about a Spark Plug Heater. Disregard the list if the heater is an HSI type---- troubleshooting is different.
More troubleshooting tips for a Spark Plug Type heater
Posted on Dec 26, 2008
tbugger
Jerry Magee
  • 232 Answers
SOURCE: I have a R150A heater that runs 3 to 5 minutes then shuts off.
http://reddyparts.com/pressure.htm
Posted on Jan 03, 2009
Anonymous
  • 540 Answers
SOURCE: ready heater forced air runs few minutes then shuts off
Sounds like a full services like its getting too much air,and blowing out the flame. Check your fuel filter,and add a new spark plug ,also change the vanes on the pump, thus aFuu service. these sould be performed every fall before .
Posted on Dec 18, 2009
Anonymous
  • 188 Answers
SOURCE: only runs for a few minutes than shuts down ithas only been used
You may have contaminted fuel, a dirty nozzel, or you may need to replace the filters. Defective spark plug can also cause this. You can go the manufacturers webite a www.desatech.com . They offer service manuals that should be able to assist you. Thank you
Posted on Jan 28, 2010
Comfort zone infrared heater runs for a few minutes a then completely shuts off
if unit runs ok for 3 to five minutes then completely shuts all power lamps off , then its hi temp limit sensor (safety) has been tripped , this usually goes out due to failure of main temp control , in point of fact contacts in temp switch literally weld them self's together and cant separate to allow heater to control temp
Oct 15, 2016 | Comfort Zone CZ1500WC Infra-Red...
Heater Shuts Off after 2-3 minutes
Does it matter if the thermostat is 120v or 250v?
Jan 31, 2014 | Lifesmart Renew Infrared Quartz Heater...
Heater runs 1 cycle then turns off
Replaced 301 80C 16A thermostat, purchased on ebay for $6.00, fixed problem. to Fix standing at front, Remove left side panel, two small screws hold thermostat in place. LifeSmart wants $36.00 for same part. Fixed problem.
Oct 18, 2013 | Lifesmart Renew Infrared Quartz Heater...
Duraflame heater runs for 5 mins and shuts off
try cleaning off the filter that is on the bottom in the back of the unit. It is a fail safe sensor that in the event the unot overheats it shuts off the heater. Worked for me on mine.
Oct 06, 2012 | Duraflame Colby Indoor Infrared Quartz...
I have life smart infrared heater 1500w. when power source on. turn power button on and set temp. unit runs and blows warm air for about three to five mins then shuts off. can restart with power button but...
The thermostat needs to be replaced. The Company sent the replacement part for free. The also said they would send the instructions to fix it, but they did not. I am looking for instructions online. ;-(
Nov 17, 2010 | Heating & Cooling
My heater runs for about 10 minutes then the flame cuts out and can't be turned on again till it cools down for half an hour...
Hi.
Replace the flame sensor, if that does not fix the problem, check the thermostats, if it cuts off in ten minutes and then restarts when cooling down, then it is either flame sensor or thermostats.
Sep 24, 2010 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Heater shuts down prematurly
  3. test photocell
Dec 25, 2008 | Reddy R70ET Utility Heater
Wont run
check the flame detector it may be a millivolt generator or a flame rod feeding to an electronic circuit.
Nov 16, 2007 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Reddy Heater-30-55,000 BTU Variable Logo
2,026 people viewed this question
Top Reddy Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Fahr Quad
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
