Question about Paragon 8145-20 Defrost Timer
I have a Paragon 8145-20 D-Frost-O Matic installed in on my walk-in freezer. The ice is accumulated on the fins of the freezer. Now it run for 11 minutes then stop for 3.5 minutes. I think the stop time is not long enough to defrost the ice. How can I set the defrost time longer?
Posted by Tai Bui on
Gene Haynes
  • Paragon Master
  • 5,391 Answers
1) Copy following links:
http://waterheatertimer.org/images/8145-work-image.jpg
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
2) Typically the 8145-20 defrost cycle is time-initiated and starts when tripper pin located on outer part of dial passes the time-of-day point.
Defrost cycle terminates or ends when pressure or temperature switch activates. This is also called the cycle limit switch.
http://waterheatertimer.org/images/8145-20-wiring-600.jpg
3) So your situation sounds like the pressure or temperature switch is not working correctly.
4) The 8145 timer also has 'time termination' setting. This red tripper is located on inner part of dial.
Usually the 'time termination' is used as back-up system if the pressure or temperature switch fails so that defrost cycle will not continue melting everything in freezer.
5) To solve problem until pressure-temperature switch is replaced, you can disconnect wire on terminal X, and then set 'time termination' for correct length of time by experimenting.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Dec 27, 2012
1 Related Answer
Anonymous
SOURCE: Set defrost timer on Paragon Electric Defrost-O-Matic
the problem is not necessarily with the timer. it seems you have more than ample time and time allocations to perform a complete defrost. most walk ins should have roughly 25-40 minutes of defrost every 4 to 8 hours. if you defrost with a heating element, you may have a problem with the strength of the element,or the element may be pulled away from the coil. you could also have a problem with the defrost thermostat(allowing the defrost to terminate prematurely)
Posted on Jun 17, 2009
Frost in freezer
You can switch off the freezer from time to time to let the ice to melt.
Of course the too much accumulation of ice will affect the freezer.
Mar 17, 2012 | Kenmore Elite 78722 78729 Bottom Freezer...
Ice accumulates on the bottom of the frezzer
if frost free freezer then maybe drain tube plugged up with ice.defrost freezer and restart (unplug till ice melts)or drain hose is dirt plugged
Nov 23, 2011 | Samsung RS2630WW Side by Side Refrigerator
What is the part number for timmer control of the T49 two door freeze
is it a Refr. or a Freezer for mthe freezer you can use a paragon model 8141-00-oem D-frost-o-matic timer control................good luck
Jun 15, 2011 | True T-49 Side by Side Refrigerator...
The freezer is accumulating frost. i have
Some models like yours came with a defrost control board and others came with a defrost timer. They should be found inside the fresh food compartment and behind the temperature control panel. You will need to inspect and let me know which you have. Unplug first. If the control board looks or does not look burned it could be bad. The timer can be turned clockwise until compressor stops and should remain stopped for about 25 minutes. and then turn itself back on. If these look good then we need to remove the rear panel inside the freezer and test the defrost element with one wire disconnected to check for continuity. Just to be sure the element has not burned out. The defrost thermostat is connected to the defrost element and will have open contacts inside it above 50 degrees. Do these test with power unplugged and let me know what you find. Sea Breeze
Jun 21, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana freezer on the bottom not keeping temperature
Hi, If you had ice, there is a drain plugged in the freezer. If you had a frost build up, there is a problem with the automatic defrost.
I can help in either case. Please let me know if you need more assistance.
Thakns
Vic
May 13, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
Excessive frost buildup in bottom freezer section of Kenmore refr
There are several reasons this can be happening...
1. The seal on the door may have a tear or may not be seating properly...this allows excess warm air into the freezer compartment and in its effort to remove the same ...frost appears.
2. There is something call a thermistor that is cycled on and off as needed to remove excess frost accumulation and or ice buildup on the evaporator (freezer) coils...it is a heat strip which actually defrost the frost/ice. if this is not working frost will accumulate and eventually it will become Ice......now the remarkable thing about Ice accumulation is that you would think everything would remain cold or get colder ..however in this case the opposite occurs...it insulates the coils and thereby increasing the temperature...put a thermometer...one that is calibrated properly...(calibration can be set by placing a thermometer into a glass of ice water...the temp of a glass of ice water..after a few minutes setting will be exactly 32 degrees)..if the temperature of your refrigerator is gradually rising over the period of a week...you will need to call a tech or replace the thermistor and or trouble shoot other problems that can occur such as..
3. The evaporator fan may be going out although they usually make a high pitched whining noise of a whirring noise before they go out...not always and if they are intermittently cycling off then frost would build up...do you always here a fan running when you open the freezer...if so that is good...fan is working...but it may be cycling off at times when no one is aware.
P.S. the odds of your ice maker causing this are very, very slim...in 35 years in the industry ..I have never had an ice maker cause frost due to water spray...it will almost always result solid sheets of Ice..if it evers does cause a spray....which like I said is rare...lottery ticket type rare :-)
This should lead you in the right direction...if you need help in finding a reputable service company in your area let us know..I hope this has been helpful..if so PLEASE rate me....thank you... .......The Fang
Mar 26, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Trio bottom freezer frost free. Producing frost
2. There is something call a thermistor (which senses temp and ice build up) that is cycled on and off as needed to remove excess frost accumulation and or ice buildup on the evaporator (freezer) coils...it is a heat strip which actually defrost the frost/ice. If this is not working frost will accumulate and eventually it will become Ice......now the remarkable thing about Ice accumulation is that you would think everything would remain cold or get colder ..however in this case the opposite occurs...it insulates the coils and thereby increasing the temperature...put a thermometer...one that is calibrated properly...(calibration can be set by placing a thermometer into a glass of ice water...the temp of a glass of ice water..after a few minutes setting will be exactly 32 degrees)..if the temperature of your refrigerator is gradually rising over the period of a week...you will need to call a tech or replace the thermistor and or trouble shoot other problems that may have occur such as..
P.S. the odds of it being due to overfilling are slim...I have been in the industry for 35 years and that is what freezers do...which a lot of people don't realize is that freezers don't actually cool anything ..they just remove heat and when you remove all the heat all that is left is cold (like in space) and when heat is removed quickly frost can appear like when you blow your breath on a freezing cold window..then right your name....but I digress...any way..if there was an excess of heat due to a lot of new food in the freezer it would correct itself by one of the processes i mentioned above..and it would never result in Ice..you probably have one or more of the problems I mentioned...evaluate how long its been going on...
4. Thermostat could be out of adjustment..and or not functioning
properly..which would delay or inhibit a defrost cycle..from occurring..unfortunately almost all of these problems require a tech...or a good handyman.
Mar 23, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
If the air flow and temperature are not being compromised leave it alone. If there is a gradual build up of ice on the evaporator you may have a defrost element or defrost limit switch problem. Set the defrost duration duration to 45 minutes and see if that solves the icing problem. 4 defrost cycles a day should be enough to keep the icing problem at bay. 3 defrost cycles at night about 1 hour apart may also remedy the problem. Experiment until you find the right combination of defrost cycles for your freezer. Watch for any thawing of the product in the freezer and adjust accordingly.
Bills Refrigeration/Montana.
Nov 14, 2008 | Paragon 8145-20 Defrost Timer
Frost accumulation on ice maker
Normally the frost is taken away during defrost so if things get worse we need to look at the defrost timer.If freeze temps.begin to rise let me know, Thanks JT
Oct 24, 2007 | Frigidaire FRS26KF5C Side by Side...
Paragon 8145-20 Defrost Timer Logo
429 people viewed this question
Top Paragon Hardware & Accessories Experts
Gene Haynes
jdthefixer
Are you a Paragon Hardware and Accessory Expert? Answer questions, earn points and help others
