NO GLASS in microwave door
There should be glass.
GE Customer Service is here.
SOURCE: GE XL1800 Door
For one if stuff had got between the two glass plates the you need to replace that seal that can be harmful for any one standing in front of the microwave when it is running.
SOURCE: condensation betwejn the front door glass
This would require disassembly of the door panels, which is not recommended unless really required.
You can download the installation guide to help you troubleshoot and correct your venting issues. That should be priority one.
It may be a clogged filter, a bird's nest in the outlet, etc. etc. Failure to vent can cause control panel and keypad trouble if it continues.
The manual / guide is found here: http://www.geappliances.com/service_and_support/literature/
SOURCE: JVM1871sk04 GE XL 1800 Microwave
PS50009 is the part number for your glass plate that will cost you $60.00, go to partselect.com, simply put the part number... and place an order ....you know what to do next...
cheers pls mark my solution
SOURCE: condensation inbetween glass door on GE Spacemaker
Your glass seal has failed and I doubt it makes sense to replace the door. Yes, it can be dangerous as the moisture becomes worse you risk the chance the glass could over-heat and blow out. Sounds like you need to replace it, sorry!
SOURCE: How do I clean the inside glass on the door - GE Profile JVM1870
I have a Kenmore with similar issues.
Model 665.61639100
Anyway, good luck with this. Hope someone has an answer for you (and me).
Mine has a open slot on the top front of the door. Kinda like a double plate window execpt for the opening in front. Why is this there? I don't know. Weird design. But it leaves for the possibilty of liquid to splash in there leaving it hard to clean (like impossible).
I'm thinking I have to completely remove and disect the door.
