I have this TV. Just pulled it out of the box. Never been used before. It goes from bright to dim every half second and is getting faster. Picture is clear. Brightness giving a headache. What do? I'm
Posted by specialist_s on
isaiah newman
    New Friend:
    Problem Solver:
  • 13 Answers
Go into your menu and check the options in brightness, and put down brightness and contrast, if that doesnt work the problem may be your computer.
Posted on Dec 27, 2012
5 Related Answers
Anonymous
  • 1139 Answers
SOURCE: Sharp LC-42D43U 42 in. HDTV fades and fluctuates in brightness.
Hello bcall8,
Have you tried watching the TV function when just viewing normal TV? Does the problem still occur? I think the you may have a signal problem in the path between the DVD player and the TV, check your cables. Now what might also be the issue is input of the TV try using different inputs, sometimes there are incompatibilities with some of the input ports and equipment used on those ports. This happens often. If all else fails I would get a schematic and start looking at the RF, HDMI, Composite Video, S Video, and component video inputs and start comparing signals with the information from the schematic.
I hope this helps,
Thank you,
Shuttle83
Posted on Dec 29, 2007
Anonymous
  • 84 Answers
SOURCE: help with settings - blurry SD picture
contrast full, brightness, tint, color, in the middle, then adjust sharpness for what suits your eyes, you may turn brightness and color below middle.
Posted on Mar 23, 2008
Anonymous
  • 7 Answers
SOURCE: Dim backround and display on westinghouse LTV-40w1 HDC tv
u will have to go into service menu to set sub brightness be carefull u may do more bad than good write down all valus before atempting to adj.
Posted on Dec 23, 2008
Anonymous
  • 50 Answers
SOURCE: TV Screen Dims during dark Scenes
Most likely you have the opc feture on. go to the menu under picture setting first option should be to turn on or off the opc. turn it of and should solve the problem.
Posted on Mar 18, 2009
OT Bobby
  • 105 Answers
SOURCE: The TV brightness dims when the we get a dim scene
This is probably normal and called "Dynamic Contrast". Maybe this company has some other proprietary naming.
Basically, the Backlight (LCD) or Bulb (Projection) will be dimmed during dark scenes to allow the TV to make a deeper black.
Posted on Apr 29, 2009
Picture brightness goes up and down while watching movies
T'Con board fault. Its ABL (Automatic Brightness Limiter) section circuit not functions well. Replace it. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 07, 2015 | Hannspree ST329MUB 32 in. LCD TV
I have a proscan tv and the light on the picture goes from bright to dim every three seconds ? What's wrong with it
Back-light problem. Contact any service technician. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do a search by type in the brand name of your device at its search box. It will be best to replace the inverter board as card basis.
Jul 19, 2014 | Televison & Video
Hitachi 32UDX10S picture is dim with brightness at 100%
The led backlights may be failing or the driver circuit isn't working. TV Parts Universal TV Stands DLP Chips ShopJimmy You can get parts and led testers here.
Feb 12, 2018 | Hitachi 32UDX10S 32" TV
Ln55c650 keeps flashing bright to dim very fast after about 30 minutes of being on if i shut it off for a few minutes it goes away til about 30 minutes the picture never goes away just gets bright and dim...
I had the same issue occur on my ln55c650 (screen flickering, not the actual image but the front lights flashed which was too distracting) and they had to replace the power supply pc-board. Seems some issue with power module in the TV rather than the side panels. Luckily for me, TV was still in warranty.
Jul 22, 2011 | Samsung LN55C650 TV
Dim picture
Turn the contrast setting all the way up.The brightness setting about half.The rest set half too.The tv picture should look fine.
Jul 06, 2010 | Sony KV-32FS12 32" TV
My dlp tv seems to be dimming.. Is that the lamp
it does sound like your lamp is going out. this happens after 2.5-5 years depending on the tv and amount of use. You can find cheap replacments and sometimes can get them a discount if you buy 2.
comment if you need sites or info on replaments
Mar 17, 2010 | Samsung HLR5688W 56" Rear Projection HDTV
My TV goes too bright at times and is too Dark on
Chances are you have a main board issue, you can test the PMW terminal coming into the power board and see if that voltage is dropping off when it gets dim, that is the signal that controls the backlight level...Good luck!
Jan 31, 2018 | Televison & Video
Sony kdf e55a20 picture goes black sound stays on
Thanks for updates.
Its time to replace Lamp. Please buy original Sony Lamp for Sony TV and avoid aftermarket or compatible parts for good performance of TV.
You can purchase original Lamp form Sony Accessories Store. Just type TV model in search box and see details by click search.
Good Luck
Jan 17, 2009 | Sony KDF-E55A20 55 in. LCD Television
Picture washed out, can't get it right
LCD TV TroubleshootingThe defective LCD TV may have the following common symptoms:
Symptom: No picture on screen but LCD TV still has sound.
Solutions: The problem is cause by defective inverter. Replacing ivnerter will solve hte problem. Symptom: Screen flash on and off between 1/2 to a few seconds, but power indicate light stays on and TV still has sound.
Solutions: The problem is cause by defective inverter. Symptom: Blue Screen but no picture
Solutions: The problem is cause by defective Main Board(AD Board). In some cases, this problem may cause by the defective Screen Controller board. Thsi board is mounting on teh back of LCD TV Scree. Symptom: Power light stays on but no display and sound
Solutions: The problem is cause by defective Main Board(AD Board) or Power supply board. Symptom: No Power or Power indicate light does not lits
Solutions: The problem could cause either by defective Power supply board or defective Main Board(AD Board). Symptom: Screen is half dim and half bright
Solutions: The problem is cause by defective LCD Panel.It needs to be replace.
Sep 21, 2008 | Akai LCT2715 27 in. LCD Television
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
