Fuel is getting to fuel filter and to the the air ntake
SOURCE: 1993 Ford Tempo cranks but does not start. Has spark.
REPLACE THE FUEL PUMP, VERY COMMON PROBLEM IN THE TEMPO.
SOURCE: location of fuel filters - 1991 ford tempo
there is one and it is located under the passenger side toward the back by the gas tank.
SOURCE: 87 ford ranger wont start without starting fluid
It sounds like you aren't getting fuel out of the cold start injector... remove the injector when engine is cold and switch on ignition... you should get a fine spray pattern for a few seconds... if not then there is probably a problem with the cold start circuit (Temp sensor fault), or the injector is faulty. pull electrical connectors one at a time and look for corrosion... Hope this helps...;-)
SOURCE: 93 ford tempo gl will not start believe it is fuel shutt off
Does the starter crank the engine over?
SOURCE: 92 ford tempo 4 cyl.too fast idle goes about 35
still sounds like a vacuum leak or intake leak, you need an anyliser for the codes
