Cameras Logo
Kelly Coates Posted on Dec 26, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When aswering yes to format, it continues to say waiting..... and won't do anything else.
I just bought it today, I put memory card in and turned it on, I then said yes to format it and it continues to say waiting with the hourglass. It wont do anything else.
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Jazz Master 102,366 Answers
  • Posted on Dec 26, 2012
Jazz Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10443613
Points
622693
What model Jazz camera? What type and size memory card?
5 Related Answers
A
Anonymous
  • Posted on Apr 28, 2008
SOURCE: memory card
i have the same problem!!!
Anonymous
  • 928 Answers
  • Posted on Feb 07, 2009
SOURCE: formatting a HP 4GB Memory card
The best thing that you can do is to try to format the card from a laptop with a built in card port or use a card reader and format it on your computer.
Anonymous
  • 11967 Answers
  • Posted on Sep 08, 2009
SOURCE: my camera wont format card
The card needs to be formatted in the camera, not on the computer. Try going into the camera menu and find "reset"...follow the on-screen instructions.
Anonymous
  • 161 Answers
  • Posted on Sep 09, 2009
SOURCE: hi,just bought a 4gb sd card for my digimax s600
Does your camera support SD HC? Anything above a 2gb SD card is concider a HC; so if your camera can't support HC format then you can not use that card.
Testimonial: "hi,thanks for the quick response,i don,t know if it has what you said.it just says on the bottom of the camera..digimax s600 cyber/630."
Anonymous
  • 797 Answers
  • Posted on Sep 27, 2009
SOURCE: my easyshare camera won`t format my SD card, but
To format the card in the computer card reader would be a way to see if the card can be formatted.
Make sure the little switch is up or in the position to format or write to the card.
If the card can be formatted in a card reader, then the card is okay. But the card should always be formatted in the camera you will use it in. There can be corruption of files when systems are mixed on one card.
Make sure that all the menu settings are at factory default, then set them as you please.
2answers
SD Card Problems with Vivitar Vivicam 5118!
What size is the memory card. If it's larger than 4GB then it won't work in the 5118.
Try using another card. Don't format it in your computer but do format it in the camera before trying to take pictures.
tip
How to recover SDXC Memory Card
Storage is getting cheaper, smaller while offering higher capacity every year. 64 GB memory cards are extremely common in today's smartphones, digital cameras, tablets and media players. Due to their sheer capacity, a single failure can cause a local catastrophe with that much information being gone.
http://www.fixya.comwrite_tip-wyytcj10vubwvpdmj0eoj2yx-1-0_0.jpg
Fortunately, the market offers numerous data recovery tools that can help you get your data back. But there is something about these cards you should know before you reach for a data recovery tool.
Flash Chips: Riddled with Defects
Can you believe you can buy the whole 64 gigabytes of fast, high-quality solid-state memory for as little as $20, or does it sound too good to be true? Why is an SSD drive of said capacity three to four times as expensive as a much smaller SD card with similar capacity? Isn't it using exactly the same type of memory, just in a different shell?
In fact, you can't really buy 64 gigs of high-quality flash memory for under $20, and there is a good reason why SSD drives are that much more expensive compared to SD or micro SD cards. The answer is buried in the question itself. Why you can buy a 64 GB microSDXC memory card off Amazon for not much more than $20, the actual flash memory the manufacturer puts in these cards is of a completely different quality compared to that of a typical SSD drive.
So how exactly are manufacturers able to achieve these unbelievably low memory prices? They do smart tricks to make the memory card appear as 64 GB of contiguous space while in fact the actual chip is riddled with defects.
Each memory card employs a tiny microcontroller that maps flash cells to logical addresses. The memory chips are manufactured with abundant capacity. During the manufacture, the chip is tested for defects. Unreadable blocks are simply mapped out and become non-addressable and inaccessible from the outside. Bingo! We've just turned an imperfect chip into a perfectly usable memory card. These tricks are nothing shoddy; they are used by all SD card manufacturers, and they are part of the published SD standard. If not for these tricks, SD memory would probably cost the same (or more) as today's SSD drives.
Now when you know the truth about today's flash chips... can you trust them your data? In fact, you can. Granted, SD cards can sustain a much more limited number of write cycles compared to an SSD drive. When one or more data blocks reach their end of life, the built-in microcontroller of said SD card is supposed to take them out of circulation and assign their logical address to another (working) cell. But what if that cell contained some system information such as a part of a file system? If this is the case, the memory card becomes corrupted, and you'll need to use special tools to extract information from that card.
Recovering Data from SD Cards
Luckily, we have a large number of data recovery tools available on the market that claim to recover the entire content of your memory card. But were they really tested with any of those memory cards in their compatibility lists, or do developers simply assume the recovery will work based on the same principle as traditional magnetic media? In fact, I've seen both and in between. Some products can recover all types of SD cards as they claimed, some other tools can't deal with SD cards at all, while some other tools can only recover SD cards up to 32 GB.
Wait a minute... Why the 32 GB limitation? Why some of the tools can recover 32 GB cards, but fail miserably when reading a 64 GB one? Should the tool either work or not? The reality is more complex than the numbers. While SD memory cards up to and including 32 GB conform to the SDHC standard, larger SD cards (64 and 128 GB) conform to a different standard called SDXC.
Recovering SD, SDHC and SDXC Memory Cards: Is There a Difference?
There is in fact a big difference between smaller (up to and including 32 GB) and larger (64 GB and up) SD cards. The former conform to the SDHC standard, while the latter use the newer SDXC standard.
For you as a user this can mean two things.
  • First, if you are using a 64 GB memory card, make sure that both your portable device and your computer's SD card reader advertise support for SDXC cards (or simply put, they explicitly state support for 64 GB SD cards). If your card reader is old and can only support SDHC cards, you won't be getting anything but errors if you try to read that card with your computer.
  • Second, SDXC cards are formatted with a different file system. Let me explain. When SD cards initially appeared, they used FAT32 as a file system. FAT32 was good enough in the old days. However, this file system has inherent limitations, restricting maximum file size to 4 GB. Just a few years ago this would be a laughable limitation. Today, a typical HD video will already run you more than said 4 GB. If you try to save a large file onto a 32 GB memory card (formatted with FAT32), the write operation will fail.
This is why the SD consortium decided to use a different file system for the new generation of SD cards. 64 Gb, 128 GB and larger SD cards come formatted with exFAT.
exFAT is a new file system developed by Microsoft. exFAT is based loosely on the original FAT32. However, exFAT does not have the limitations of the older FAT/FAT32. exFAT is extensively used in portable electronic devices due to its lightweight design. This was one of the reasons exFAT was selected by the SD consortium as a standard file system for the SDXC format.
Are there downsides to exFAT? There's one, but it's a major one. While exFAT is designed and owned by Microsoft, it's not free. Microsoft requires manufacturers pay licensing fees for using exFAT in their devices. As a result, this has become a limiting factor for many portable electronic devices, especially inexpensive ones. This is one of the reasons why you can use 64 GB SD cards in some devices but not in others.
As a result, when recovering data from a 64 GB SD card, you'll need two things:
  • An SD card reader supporting SDXC (or stating explicitly that it can read 64 GB SD cards);
  • A data recovery tool that supports exFAT;
Not all data recovery tools can support exFAT because of the restrictive licensing model employed by Microsoft. Even if a tool advertises support for "all types of memory cards", it may or may not support exFAT. One of the tools known to support SDXC memory cards and exFAT file systems is Hetman Partition Recovery.
But I've Just Bought a 64 GB SDHC Card!
Sigh. This chapter is probably the most disturbing part of this article. Every other week, we receive an email from a customer describing a typical situation. Because there are so many reports, and because they all describe the same thing, let me just summarize it below.
A guy buys a 64 GB SD card for a price that's significantly below the market. When the memory card arrives, he tests it in his computer, discovering 64 gigabytes of usable capacity. Suspecting that 64 GB of flash memory for under $5 could be a scam, the guy tests the card by writing some data. The writes are extremely slow (3-7 MB/s), so testing the entire capacity would literally take the whole day. He writes some 1-4 GB of data and reads it back. All seems fine, so the guy formats the card and puts it into a phone, MP3 player, digital camera, or whatever portable device he bought it for.
Day after day, week after week the card is filling up with data. Pictures, music and videos are saved onto that memory card. 8 gigs, 16 gigs, 32 gigs, 64 gigs - the writes keep going, the memory card seems to be holding well. Then all of a sudden a photo won't show in a viewer, an MP3 file won't play, a video won't show up. The guy takes the card out and connects it to a PC in an attempt to save the rest of the data. But... oops! There are no photos, music or videos on that card, just garbage.
It is this moment the guy seeks for help and writes us an email. Sadly, in situations such as the one I described our hands are tied: that memory card was a fake. In fact, the "deal" advertises a 64 GB micro SD card for only $4.79. Yes, it's under five bucks for a 64 GB memory card. The description is Pidgin English and reads something like this: "New 64 GB Class 10 Micro SD HC Memory Card with Adapter Fast USA Shipping Dependable memory card for your favorite photos, videos, apps, and games Easily transfer files between phone, tablet and camera" blah, blah, blah.
Remember: if it seems too good to be true, it's probably not true. See that "Micro SD HC" designation? It's a dead giveaway. You can't buy 64 gigs of memory for $5. And, THERE ARE NO 64 GB SDHC CARDS, period. The SD standard dictates that all SD cards with capacities higher than 32 GB are made to conform to the newer SDXC standard. If you buy this card, you won't be getting anything but a fake.
Ditto. Do not buy these. Remember how the packaging looks, and ignore deals that seem too good to be true.
SDXC Recovering 64GB and 128GB Memory Cards Hetman Software
2answers
How to format my memorie card
First of all, get a memory card reader, if you don't already have one. Then plug it in your computer. Go to My Computer, select the Memory Card drive, right click and select Format. It will appear a box, where you probably won't need to change anything, so click Start. Wait till it completes and you're done.
Feb 27, 2012 • Cell Phones
I have had my camera for 3 years but never had bought a memory card for it. I recently purchased one from Walmart. When i put the memory card in the digital display almost gets stuck and won't open so...
The camera takes SD cards up to 2GB (not SDHC cards). If you've been taking pictures using the camera's internal memory, you must first get rid of those pics. With no card in the camera, go into the menu and find "format" and follow the on-screen instructions. Then, insert your new card and go through the "format" routine again to prepare the new card.
4helpful
2answers
Camera says out of memory won't let me take pictures. i cleared all the pictures out and still cant take pictures. What do you think the problem is?
I'm assuming you are trying to use an SD card in your camera and not the internal memory. I suggest you format the memory card if you are sure there is nothing on the card. Formatting the memory card deletes everything on the card and sets it up with a file system that your camera recognizes. Follow these steps to format your memory card using your camera. 1. Turn camera off 2. Insert memory card 3. Turn camera on 4. When the memory card is inserted in the camera, the [Format card] option appears in the setup menu 5. Choose Format to format the entire card. Don't choose Quick Format 6. Wait until your card is formatted
After formatting your memory card, try turning your camera off and on and you should now be able to take pictures to your memory card.
P.S. If you remove your memory card you can choose Format Memory from the setup menu to format the camera's built-in internal memory
I purchased a memory on sunday - took pictures and downloaded to computer but did not delete from camera. today i took more pictures and reviewed them - all was o.k. before downloading onto computer, i...
Take no more pics until you've recovered your photos, take the card out of the camera. This is to reduce the chance of you overwriting some of your "lost" photos. There are many good freeware photo recovery software options that may help you recover your photos. This article reviews and outlines several of the better ones. Now after you've recovered your photos, consider formatting the card in the camera to prevent this from happening again.
2answers
Memory card won't format continues to ask yes/no erase memory and then repeats after selection is made, can't get to the menu when new cf card is in
I've tried to send you a message 3 times so far today - not sure if this helps but a tech site suggested that the max capacity tested for the HP 318 was 16 MB - my card that I tried today was 8 gigabytes ..
I ordered a 16 MB card - hope it works. Good luck to both of us!
Mary
[email protected]
My son is attempting to save a game (SPYRO Riptos-Rage). Error shows "Memory Card is not inserted." We just bought a new one today because we thought something was wrong with the other one. One is 8MB the...
You may need to format the card first before you use it.
Insert the PS2 memory card into the first memory card slot on your Playstation 2. Make sure that the card is all the way in the slot the card may not register when you turn on your Playstation 2.
Turn on the Playstation with no game or DVD inside of it. Wait for the main menu to pop up on your television screen.
Using your PS2 controller, highlight the memory card option and press the X button. This will open up the memory card menu, which will allow you to delete data or transfer data from one memory card to another.
Wait for the Playstation 2 to send you a prompt asking you to format your new memory card.
Click "Yes" when the formatting prompt appears on the screen. This will automatically format and set up your new memory card for use with your
Clarification
Install the memory card in the device and hook the device up to the computer with the USB cable. Go into my computer and the memory card should show up as a removable storage device. Right click on it with you mouse and select format from the drop down menu. If your computer has a card reader slot on it for your memory card you can just plug it in that slot and repeat the process above. You can also buy an external usb memory card reader for under 10 bucks and also use the same process. Formating the card will prepare it so that you can save files on it. Formating will also erase anything on the card so make sure you save anything you need on it before you format it. If you need more help feel free to cotact me an I will help you more for free but I think I aswered your question as fully as possible with every way you can format a Memory card. Please take the time to rate this fixya. If you need more help [email protected] feel free to ask me any questions you have.
George
Ps. I do this because I enjoy helping people and it is a fun hobby I will never charge you for anything I teach you
Top Jazz Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Jazz Camera Expert? Answer questions, earn points and help others
