Question about Bunn CWTF Coffee Makers & Espresso Machines
I have an Bunn model GRX-B datecode 304009 that leaks at the bottom, what can be done about it
Is this item on recall
Posted by Bill Price on
RJ Keck
    Novelist:
    Scholar:
  • 166 Answers
Most likely cause is that the seal between the water reservoir and the tank is leaking. Not uncommon. If you can find a replacement seal go for it, otherwise the old one can be made serviceable by coating both sides with a thin bead or layer of clear silicone. Allow to cure for 24 hours before powering the coffee maker back up.
Posted on Nov 23, 2014
5 Related Answers
Anonymous
SOURCE: Bunn Coffee Maker Leaks out the bottom
Hi I have had this problem twice....this time I took off the top of the maker to check it out and noticed something loose and this fixed the problem, on mine at least. Lift the lid and take out the two Phillips screws, and remove the grid. Take out the three (or four) Phillips screws on this level and remove the top of the maker. There is a tube, with a hex nut around it, under the swivel arm that shuts off the water when the lid is up. On my maker this nut was very loose, even though the seals were still good. I tightened it with a pair of pliers( don't over tighten) and it hasn't leaked since. I also cleaned the water tray out while I was at it , as it looked rather yechhy. Reassemble and put the screws back in (don't over tighten, as they are in plastic)
Posted on Mar 31, 2009
FixinFax
Leroy Elliott
  • 3085 Answers
SOURCE: MY Bunn coffee maker GRX leaks .
Complain loudly to Bunn, they fixed mine for free.
Posted on Dec 09, 2009
atbsmmom
  • 189 Answers
SOURCE: Bunn GRX-B leaking from bottom
If you will locate the date code on the bottom of the brewer and contact Customer Service, the machine can either be replaced or repaired at not cost or if over 3 years old, at a reduced price.
Posted on May 19, 2010
atbsmmom
  • 189 Answers
SOURCE: Need wiring diagram for Bunn BX or GRX coffee
I do apologize but these diagrams are not available. What is the problem with the machine? If you will get the model and code date from the bottom of the brewer and contact customer service, we can help resolve your issue. The machine carries a 3 year warranty and if it is 3 years old or less, it will be replaced at no cost. If it is older than 3 years old, then it will be replaced at a reduced price.
atbsmmom
  • 189 Answers
SOURCE: I need a wiring diagram for a Bunn BX coffee maker
Is there a current recall on Bunn model GRX-B?
Don't know about a recall, but the most common cause is a bad element.
Jan 22, 2014 | Bunn GRX-B
The lid to the coffee pot itself is broken .. bunn model GRX-B - can I buy a new lid?
We will be happy to replace that lid free of charge for you. Please call customer service at 800-352-2866 and we will send you one out.
Dec 29, 2010 | Bunn GRX-B
I have a Bunn GRX-B Model Serial # 243908. It is leaking water while brewing at the bottom on the on/off switch side. What is needed to correct this? It is more than 3 years old.
Your brewer is still under the 3 year warranty. If you will call us at customer service at 800-352-2866 we will be happy to send you out a new machine.
Dec 09, 2010 | Bunn GRX-B
Mar 22, 2010 | Bunn 10 Cup Home Coffee Brewer
It won't stop dripping and is leaking from the bottom. The dripping is coming from where the coffee would come out. This has been going on a couple of days. The leaking from the bottom has been going on...
The leaking from the bottom may stem from a broken or melted gasket on the interior. Some owners report success receiving the repair parts/instructions by mail. The customer service department at BUNN will assist you at no charge. Before you contact BUNN, enter your model number in the web and the word "recall" to see if any such issue applies. There were several such recalls in recent years, in which case it does not matter if your unit is under warranty or not. If applicable, BUNN will explain your repair/replacement options.
BUNN contact info. and hours of operation appear here:
https://www.bunnomatic.com/retail/service/contact.html
Mar 05, 2010 | Bunn 10 Cup Home Coffee Brewer
My BUNN GRX-B is leaking water when brewing. I think it is out of the back?
Please get the date code located on the bottom of your brewer and contact customer service. The machine has a 3 year limited warranty and we can replace it free of charge. If it is over 3 years old, we will replace it at a reduced cost.
Dec 01, 2009 | Bunn GRX-B
Bunn coffee maker leaks all over the counter. What
there's probably a 'silicon rubber' hose that feeds hot water to the 'grounds basket'- it may be loose, or damaged. is it leaking water, or coffee?? we have a bunn 8-cup, which has a pre-heated water tank that brews a pot in about 3 min. energy waster, but when you need coffee, you need coffee!!! is your filter holder properly centered? is the carafe lid hole clean and un-obstructed?
if it's leaking water, and not too costly to replace- you may consider replacing it with a new one!
good luck!
Oct 09, 2009 | Bunn GRX-B Original 10-Cup Home Coffee...
It is shorting out, model GRX-W Bunn
Please contact customer service with the model and code date. If your machine is 3 years old or less, we can replace it free of charge. If the machine is over 3 years old, we can replace it at a reduced price.
Sep 27, 2009 | Bunn GRX-W
Coffee Makers & Espresso Machines Logo
118 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
