When I connect all I get is sound from the small tweeters. I connected to the main A connection on the tuner..
SOURCE: Durabrand HT-3917 System Problem W/Rt Frt Spkr
chck the wire fist if it is ok, use tester turn to X10,
SOURCE: Problem connecting Onkyo Amplifier to Bose Accoustimass speaker system
This is probably correct as modern equipment uses electronic volume controls rather than potential dividers the range is normally biased towards the bottom end so there is lots of the range that is quiet and a smaller part that is loud.
Unless you find that at the top of the volume range the system does not seem to be loud then it is probably correct. It is not uncommon for modern equipment to clip at 80 / 90% of the volume range. Where as old style equipment with volume pots used to clip at arround 30% of the volume range as it gave the apperance there was loads of extra volume available. In fact all that happened if you turned it up louder was it clipped more and more.
Regards,
Andrew
SOURCE: Samsung HT-X40 System Problem
while in stop mode, go to the menu and select Sound Setting, then go to delay setting. You can fix this problem by choosing the right delay time.
SOURCE: Prima HT 8104 home theatre
in the 3D processing turn on the Pro Logic and the for the mode as well set it to pro logic.
it simulates 5.1 surround.
this is what I did and it's decent. Other way would be to run the system through a amp/receiver that supports 5.1 surround.
SOURCE: How do I connect my Acoustimass® 5 Series III
Well, first of all this speaker system is designed to give you a subwoofer where you do not have a sub-woofer output on your receiver/amp. However, that is not the case with the Onkyo. The way I would set it up (only because of the speakers you have) according to the Acoustimass Manual. You take the left and Right "Speaker" outputs to the Left and Right input on the Acoustimass and the speakers crossover does the rest. The Onkyo is designed to have a powered subwoofer so in this format you would just tell the receiver to turn off the sub channel which would tell the Onkyo to send the low end to LR. That should do it.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Onkyo-HT-S5300-Home-Theater-Systems-manual/id/23655bh932/t/2/
