Question about HEWLETT-PACKARD Office Equipment & Supplies
MY HP officejet Pro 8500 Premium all-in- one printer has an error message, which states that printer is off, even though it's actually on. Please help.
1. My HEWLETT-PACKARD Hp Pavilion Elite HPE-180t is running slow. How can the speed be increased, for faster performance? 2. MY HP officejet Pro 8500 Premium all-in- one printer has an error message, which states that the printer is off, even though it's actually on. Please help.
Posted by Isaac Gbehan on
DONNA HILL
    New Friend:
    Problem Solver:
  • 5 Answers
I need to address question 2 before 1.
2. If your error message says it is off, or off line try this. Go to control panal. find printers and double click. Find you printer and right click. You should see use printer online. If you do, click. Go back right click on your printer, and click Set as default printer. This should do the trick. If not you will have to give me a little bit more info on the problem.
1. Go to control panel. doulbe click on printers, Find your printer , and right click. You shoud she printing preferences. left click. at the top you should see tabs (General, layout advance) some printers have more than those tabs. Click on the General tab. In the body of the box you should see something like print quailty. In that box it shoud have, draft, normal, best, or something equilivant to that. If you click the draft, you documents will print fast. However, if you want something to print in normal mode or best mode, for a particular project, without going back in and changing your preferences. When you start to print, a window should pop up and give you options to change this before you print. (Just for that project). If it does, click on prefrences, and change it to normal or best. you can also change color mode, to black only in this print box if you don't want to waste your color. This will not change your original preferences, it only changes it for that project.
Posted on Dec 28, 2012
5 Related Answers
Anonymous
SOURCE: Paper Jam HP OfficeJet 8500
etechrepair.jpg Constant jam indication. This gear is more than likely the cause after exhausting all other avenues. Also nearly impossible to get to let alone replace even if HP offered the part. There is a black cover over the clutch assy that can be removed to reveal the gear. In most cases the gear is either sitting in the bottom of the machine or split down one side. This is the second machine that I have diagnosed with this problem in a very short time. If you have this broken gear, consider it toast. Matt / E-tech Copier and printer repair.
Posted on Jan 19, 2011
SOURCE: HP Officejet Pro 8500 has a paper jam. Can't get
Hi! I will be glad to assist you in this issue, here is the link that will fix the issue:
Paper Jam' Message Displays on the All-in-One
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01617494&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3752459&lang=en
Carriage Jam' Message Displays on the Control Panel Display
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01618201&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3752459&lang=en
Posted on Oct 11, 2009
Daniel S
Daniel Scott
  • 4323 Answers
SOURCE: Try to print but: get General Printer error 0x61000f6
Hi
This error comes due to carriage jam. Turn off the printer and unplug it from wall socket. Now, remove the cartridges and check for any dried up ink residue on cartridges on inside the carriage. Clean the cartridges contacts and carriage using a Q-tip dipped i alcohol. Let the carriage and cartridges dry before you plug in the printer.
Install the cartridges and check. If it still shows error then unplug the power cord coming to the printer without switching it off. Now, remove the rear door of the printer and check for any paper jams over there, remove if any. Wit for at least 15 seconds and plug in the power cord. Now check whether it is working.
Daniel Scott
Posted on Jun 22, 2010
Testimonial: "Thank you very much for the information. very helpful. I am sure this information will help other people as well. Thanks again. "
catssite
SOURCE: HP Officejet Pro 8500 printer message "Paper jam"
An error code showing that there is paper jam alert, but no paper is in anywhere in the machine except in the tray.....I have checked all areas, taken the back carriage of the unit, opened the top and opened the machine. removed the paper tray, everything, but there is no paper stuck in the unit
Posted on Jul 02, 2010
nonontech
Lebanon Raingam
  • 4737 Answers
SOURCE: hp officejet pro 8500 a909a
Press the settings button i.e the button with the wrench icon on the machine. Now select "Print Report" and then "Image on Fax Send" and set it to "ON". Save the settings and try again. It should work.
Let me know if you need further help. Good Luck.
Thanks for using FixYa.
Posted on Mar 24, 2011
Officejet pro 8500a premium power light on but touch screen is off and will not respond and the power button will not respond either
hi, Mr Justin Becker
i think its a power supply problem, first you should try another dc adaptor, if your printer works fine with the new one, you have to replace it or take it for repair.
if it is a DC Adaptor problem it cost about: US $29.74
HP OfficeJet Pro 8500 AIO GSA printer power supply ac adapter cord...
Mar 06, 2014 | HP Office Equipment & Supplies
HP 8500 OfficeJet Printer Display keeps showing a message that my Magenta catridge is empty and need to be changed even though I changed it
Try cleaning out the cartridge slot. This is very often the reason that your printer isn't recognising it, because it's dirty.
I hope i was able to help.
Jul 27, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Hello, I bought this morning a printer Hp officejet pro 8500 A but it doesn't work with the Mac Os X 10.4.11 I have. Please may you write me where I could dowmload a driver to become 10.5 or 10. 6...
Hello, I suggest you have a dig around the HP website as there appear to be several variants of your Officejet 8500. Go to www.hp.com and it will automatically detect your country and take you to that country's web page, though I recommend you try to get on the USA site by going to the bottom of the page and clicking on the world icon. Once there, select 'drivers and downloads' and on the next screen type in your model type, ie 'Officejet Pro 8500'. When I did this several versions came up and only you know which one you have!. If you go to the drop-down menu to select you OS, Mac OS X comes up with no version type, but if you go to the top of the page you'll 2 boxes, in the 'Product' one, make sure you've got 'Officejet Pro 8500' in there, and in the 'question or keyword' box type in 'what version Mac OS X' then in the results you'll see quite a lot of hyperlinks to pages, and at least 2 of them refer to OS X 10.4, but as I said before, you'll have to have a good dig around yourself. Regards, nicam49
Jul 15, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
My HP 6500 709N all in one printer displays "paper jam" error message. Have searched thru printer - no jam, no little bits of paper. Have been thru the trouble shooting process - doesn't help and...
HP Officejet Pro 8500 (A909a) All-in-One Printer This model has a two-line display.
  1. Unplug the power cord from the HP All-in-One.
  2. Wait for 20 seconds.
  3. Press and hold # and 3 while plugging in the power cord to the HP All-in-One.
  4. Release the buttons after the HP All-in-One starts up.
HP Officejet Pro 8500 Premier (A909n) and 8500 Wireless (A909g) All-in-One Printers These models have a touch-screen display.
  1. Touch the Setup icon.
  2. Scroll to and touch Tools .
  3. Scroll to and touch Restore Factory Defaults . A Defaults Restored message displays.
  4. Press the Cancel button to return to the main menu.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 27, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Can't get my hp office jet pro 8500 to receive or send faxes. Husband lost the instruction manual.
Follow this link to HP Customer Care: http://h10025.www1.hp.com/ewfrf/wc/pfinder?lc=en&dlc=en&cc=us&lang=en&tool=&query=OfficeJet+Pro+8500#N447
Select your OJ Pro 8500 Model (A909n - basic, A909g - wireless or A909n - premium). On the next page, Select 'manuals'. From there you can access (read online or download & safe to your hard drive) all of the manuals.
Nov 02, 2009 | HP Officejet Pro 8500 Wireless All-In-One...
256 people viewed this question
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
Harrie
Duke Bells
Lawrence Oravetz
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
