Pictures are blurry on any setting
SOURCE: polaroid i836 digital camera
this camera has hi-resolution which takes up a lot of memory,the internal memory of the camera is only sixteen megs. all you need is to add an sd card with 1 gbyte of memory and that will solve your problem.
SOURCE: I have recently purhased a
It may have something to do with your settings.
Press the button with the diamond on it (at the bottom right hand cornner)
In picture mode, press the ok button
(I might recomend the use of a tri-pod to hold it steady)
----John
SOURCE: icant download pictures from my polaroid i737 camera to vista
go to the file on your camera where you know the pictures are and drag and drop or copy and paste all the pictures into a folder you put on your desktop or where ever you want it.
SOURCE: My new i1236 Polaroid digital camera will turn
1) The card could be write protected, check the side of the card see if there's a small notch to slide up or down.
2) The camera could have photo protection option switched on, you have to go through the user manual and the camera menu to switch that off.
3) If you don't get too far with the first options, as its new, take it back to the vendor and ask them to demonstrate it to you and to your satisfaction. If there is a problem with the camera, request a replacement or refund under warranty.
Testimonial: "Thanks for your help, I'll try it."
My photos are all blurry also. Whether indoor or outdoor, macro on or off, flash or no flash, nothing is helping
