Hp photosmart c4480
Hello,Follow the steps below:
Step one: Remove any loose paperRemove any loose paper from the input tray.
CAUTION:Do not remove jammed paper at this stage.Step two: Clear the jam from the back of the printer
Step three: Clean the rollersWhile the rear door is removed from the product, clean the paper rollers.
CAUTION:If the paper tears when removing it from the rollers, then check the rollers and wheels for torn pieces of paper that might remain inside the device. If any torn pieces of paper remain inside the device, then more paper jams are likely to occur.
Raise the top cover of the product.Figure 4: Raise thepaper goes part way in then stops. printer continu - c01345237.gif>
SOURCE: HP Photosmart C4480 printer will not print. It will copy however.
load the printer with paper
SOURCE: drivers for my HP Photosmart C4480
You can download drivers from link below.
HP Photosmart C4400 All-in-One Printer series - Download drivers .
If this had been helpful, remember to evaluate the solution.
Many thanks.
SOURCE: how to install hp photosmart c4480 scanner
hey
try this installer
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=219&lc=en&dlc=&cc=us&lang=&product=3418705
note the mac versions listed there
SOURCE: Can an HP Photosmart C4480 printer work on Windows
This unit requires windows XP as the minimum operating system that it will work, so the unit wont work with Win 98 here is a link for the complete details of this unit
http://h10010.www1.hp.com/wwpc/uk/en/ho/WF06b/18972-18972-238444-410635-410635-3655558-3655585.html
SOURCE: unable to scan a4 size paper
Check the default paper type for your scaner, change the paper size to A4 and try the can again
