I need access the 3com 4800G series switch through ethernet port , what is deafult ip .
There isn't a default IP. You have to configure it via the console port first.
http://h20000.www2.hp.com/bc/docs/support/SupportManual/c02579469/c02579469.pdf
SOURCE: 3com 3300 TM - all Ethernet port not working, power led flashing
A blinking power LED means that the switch is either downloading software, or is initializing which also includes running the Power On Self Test. You may have firmware issues with the switch and/or the switch is stuck in initialization mode. You may have to contact 3com regarding a warranty issue. Hope this helps. Good luck.
SOURCE: Routing vlans on 3com switch 4500
i can't set ip address over 4 vlans. the 3com switch 4500 always give error message "there's not enough routing resources available".please help....
SOURCE: what is the defult ip address for access the
The default IP address of the device, depends on the status of the network where the device resides, but if the device is not connected to the network, or no DHCP server exists in the subnet where the device resides, you can get the default IP address of the device on the label on the right of the device rear panel.
SOURCE: I would like to find
3Com is owned by HP now.Here is the manualhttp://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c02581570/c02581570.pdf
