Green power light on back of tower blinks and when heated with a hair dryer comes back online. what can i replace to keep from using the hair dryer?
SOURCE: System will not power up
Here is a Compaq document will walk you thorough a fairly lengthy procedure that should solve your problem. Here is the link: http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph06788&lc=en&cc=us&dlc=en&product=431080&query=presario%20sr1220&dest_page=product#N561 Let us know how this turns out or if you need any additional assistance.
SOURCE: HP a350n not powering up.
unplug power and open computer and pull the small battery and wait 30 sec and replace
plug in everything and reboot
may have to re-enter cmos utility
SOURCE: hp pavillion desktop will not
Step 1 : Turn off the system by pressing the power button for 5 - 10 sec until the power LED is off. Removed all cables including the power cable (Exclude monitor cable and KeyBoard/Mouse).
Step 2 : Press power button for 5-10 sec again to drain fela power.
Step 3 : Reconnect the power cable at the back of the tower/computer and power on the system.
**If the same problem exists, Call HP tech Support (800-474-6836) because there is a high possibility that you have a bad Motherboard or Power Supply on the system.
SOURCE: HP computer doesn't turn on
Your power supply is bad--you will need to replace. I suggest looking at tigerdiect for a replacement.
SOURCE: Tower won't turn on. There is a green light on the
Pull the power cord out and allow it to reset. If you still have issues you may need to replace your power supply.
