Question about Casio Exilim EX-Z750 Digital Camera
Do you have service center in naga city? my camera fell, lens loosen. pictue got a pink shade.
Posted by Aleth Mina on
LENS ERROR SHOW
This problem happens because of longtime no using/ Dust or Lens guide pin damaged. If the lens guide pin damagethen there is no chance for repairing . Only solution is replacing the lens. For the solution you need to follow the steps.1. Turn off the camera and remove the memory card and clean theexternal body of the camera and make sure in place of the lens there is no dustor damaged sign.2. Now turn on the camera without memory card & make sure thebattery are fully charged.3. If the lens not moving then give a little shake or thrust by hand( carefully very slow) and then wait for a moment. If no changes then turn onthe camera and give a little twist an anti clock side and leave for few second.It is risky ( Do it slowly at your own risk)4. If nothing change then reset the camera setting from the menuoption.After following all steps, if thecamera does not start working then you need to visit service center forreplacing the Lens or Repairing. But before repairing ask service center theapprox cost. if they told you to replacing the lens then do not do that.Because a new lens & service charge cost you near about a new camera price.So best is buy a new camera. If you have any more questions ask me I fell happyto answer your question. Thank you.
Sep 28, 2011 | Nikon COOLPIX S220 Digital Camera
Broken camera lens.
i guess the camera fell pretty hard denting it, the whole lens has to be replaced. u will have to take it to the service center to get the lens replaced. sorry for your camera
Apr 17, 2010 | Casio Exilim EX-Z57 Digital Camera
Most of the pictures I take with the T200 have a pink shadow and anything white has a pink shade to it.
It's a faulty CCD or loose connection between the CCD and main board. Contact your local Sony service center or if they ask too much, feel free to contact me at [email protected]
I work in a Sony service center.
Tom
Jul 18, 2009 | Sony Cybershot DSC-T200 Digital Camera
Camera fell on floor, now pictures out of focus
That's because the internal focus servomotors are out of place and can't turn the focus ring. I'm sorry but these components are located inside the lens assembly and this is not by any means an user serviceable part. It's composed of tiny servomotors, small coils and plastic parts that can get out of possition or decalibrated if the lens assembly gets opened.
A thing to try would be to hold the camera with it's lens barrel opened in one hand and hit it (gently yet still firmly) against the other hand. There are some small chances that this will bring the internal focus ring to it's former alligment. Other then this, only a service center can fix the camera, but it could turn out to be an expensive repair.
I'm sorry for having to bring the bad news.
Bogdan
Jul 09, 2009 | HP Photosmart M537 Digital Camera
Olympus 1050SW won't turn on after being under water...
Repair center in the Philippines
Quezon City Columbia Global Photo Sales Corporation
#129-1350, ROXAS
STREET, SFDM 1117 Quezon City
Tel: 363-8550, 363-7463
Apr 07, 2009 | Olympus D-460 Zoom Digital Camera
CANONIXY/80;DISPLAYS LENS PROBLEM,RESTART CAMERA
I have had the same problem. The first time it happened I thought it was because the lens got broken when a heavy object fell over it. The lens was replaced at the service center for about $ 90.00, The second time it happened, I could not think of anything that would have caused it. I pushed the power button and the function at the same time for a few minutes, and voila...the lens came out. However, after a day or two, the same problem appeared. Had to take it the service center again for repair. This camera is very small and convenient but SUCKS! It failed to work when I was in Israel and MAchu Picchu!
Mar 02, 2009 | Canon IXY 1000 Digital Camera
Pink polaroid i631 camera
Here is the solution for your problem. If you look at your camera at an angle, you will see the zoom lens2_bing.gif is little bent to the side. I want you to put pressure on the cam to snap-it into it's place. After you heard a click, then turn-on your camera. This will fix your cam.
Vicent
Jun 14, 2008 | Polaroid i631 Digital Camera
SPOTS on pictures taken by my Canon EOS Rebel XTi
Cleaning the lens and CMOS (Canon uses CMOS instead of CCD sensors) would be the first thing I would do. Before an expensive cleaning (usually at least $60) try getting a blower and blowing off the lens and sensor (find the sensor cleaning thing in the yellow section of the cameras menu, select it, the mirror will lock up, take off the lens, blow on the sensor with the blower)
For the lens, besides the blower, use a microfiber cloth on it.
If the problem persists, almost any camera store will clean cameras. Try Ritz cameras, here is a list of their stores in NY city.
Nov 25, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
When using flash the reflection have a pink tint
Lens block assy may be defactive. Consult Sony service center
Jan 16, 2007 | Sony Cyber-Shot DSC-F717 Digital Camera
Casio Exilim EX-Z750 Digital Camera Logo
82 people viewed this question
Top Casio Cameras Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Steven Wander
Steven Wander
Are you a Casio Camera Expert? Answer questions, earn points and help others
