Check if there is any USB port on your DVD player. If yes, you can play MP4 videos that stored in a USB stick. If no, you can convert DVD to MP4 and then play it directly on your computer or TV. To convert a DVD to an MP4, you need DVD ripper software. A DVD ripper is a computer application that converts DVD or Blu-Ray movie into a different file format, typically in the ISO format. But with the ripping technology development, you can rip DVD to various digital formats like MP4, MKV, etc. Read this post to get some recommendations: 5 Best Free DVD to MP4 Converters
Due to the limits of most DVD players' inner performance, original MP4 files normally cannot be directly played on regular home DVD players.
If you really want to play MP4 on DVD player, then try to convert it to MPEG2.
Here is detailed guide on how to do that, and you can have a check.
https://www.leawo.org/tutorial/can-dvd-players-play-mp4-1410.html?fixya=1410
I use iDealshare VideoGo to convert MP4, MOV, RMVV, AVCHD, MXF, H.265 etc to DVD player more supported video format with this guide https://www.idealshare.net/video-converter/solution-on-mp4-wont-play-on-dvd-player.html
Maybe your DVD player is one of those DVD players that play mp4 files and MP4 is originally supported by your DVD player and what you need to do to play MP4 on your DVD player is simply "plug and play".
Another way to play MP4 files on your DVD player is to convert the MP4 to DVD and play the DVD on your DVD player. You can try Leawo DVD Creator to burn MP4 to a DVD to play on the DVD player.
Will DVD Players play MP4 files?
As we know, most old DVD players only support DVD video on DVD disc, they cannot play any video file not to mention MP4 file. Later, some DVD players can play video files on DVD disc. Even later, many DVD players come with USB ports, users can attach USB drive to it, and it can search and play video files on it. However, the video formats they support are very limited. Because DVD video is some kind of MPEG-2 video, this format is supported by nearly all DVD players. MP4 is newer than AVI format, some players doesn't support MP4 but support AVI. Hence, to play MP4 on DVD Players, we suggest you convert MP4 file to DVD-Players-sensible formats like the MPEG or AVI format.
To solve this issue, read this guide: http://www.faasoft.com/articles/can-dvd-players-play-mp4.html
SOURCE: does cyberhome ch-dvd 300 dvd player play burned mp4 movies?
the answer is "No". Your player cannot play MP4 DVD discs.
Take care.
SOURCE: I can't play MPEG-4
Refer to its user manuals' specification sheet. You can see all details about the formats that this player can read.
SOURCE: Audiosonic 9'' (22cm) Portable DVD Player - Black?
You have to make the DVD format yourself. A decoder program or some programs to burn DVD's have this.
Look on a DVD what map structure it has and what files it contains. No MP4
Regular standalone DVD players can only read movie DVD's (those are in MPEG-2, and if you view them in Windows Explorer, you see a folder structure with VIDEO_TS, and files like .VOB .IFO and .BUP). Newer DVD players that are DivX-certified can (in addition to the above) read data DVD's with an AVI file encoded in the DivX codec. Most of the time, you will fail to play MP4 on DVD player unless the DVD players have the "Nero Digital" label on them.
In order to burn MP4 to DVD for successfully playing on various DVD players, we had better find a powerful MP4 to DVD burner which will automatically convert MP4 to DVD player compatible format as well as burn the converted MP4 files to DVD disc.
Below will introduce the free download link of the just right MP4 to DVD Burner and a detailed guide on how to use this wonderful tool to successfully burn MP4 to DVD for easy playback. at Solution on MP4 Won't Play on DVD Player
