It got below freezing last night and my car won't start and the hood release won't pop the hood so i can charge by battery what can i do to get it to release?
You have to let that hood release get warm enough so that it will pop open then put some motor oil on the mechanisim so it don't freeze up again.. good-luck ray
STICK A PORTABLE HEATER UNDER THE HOOD CLOSE AND LET IT RUN ABOUT AN HOUR. bETTER IF YOU THROW A BLANKET OVER THE HOOD. tHIS SHOULD DEFROST ALL THE SYSTEMS.. yOU STILL HAVE ice SOMEWHERE.
What is wrong with hood release?
Sometimes I use vice-grips on hood release cable, have a helper standing at the end of the hood. At the same time you pull the release cable, have the helper pop the hood in area of release mechanism with palm of hand, sometimes that works to open hood. If you get it up, lube everything.
Some makes and models, I can remove front grille and reach the release mechanism. Don't know about your vehicle?
Is your car well protected with antifreeze? If not, maybe a freeze plug came out. Living in Montana, cars stay outside all winter. I always use a 50-50 solution of antifreeze. Never had coolant freeze up. Before cranking the car, check that your timing belt did not pop. Don't know how it could, sitting there 14 hours, but turn crank slowly by hand, and check that camshaft is also turning.
Sometimes it helps to have a helper standing at the end of the hood, as you pull the hood release mechanism inside, have the helper pop the hood with palm of hand in area of release mechanism. I haven't looked to see if you could remove front grille?
If there is a national brand autostore in your community, they have been known to make house calls. Possibly, they could raise your hood, replace the battery or give it a charge, whatever. I don't know what they charge?
Sometimes you can charge your battery by hooking up battery charger to battery cable at your starter motor?
Sounds like the "hood release cable" pulled loose from the clip uneder the hood ...you will have to take a long nose plier reach up from under the car to where the under hood latch is and see if you can get hold of the cable / latch mechanism and release it that way . as far as the battery sounds like the battery is not holding a charge .
best idea i can think of is to be careful and you can connect the jumper cable to the main power at the starter and the ground to almost anything under there to get enough power to get the doors to pop its a pain but it beat paying the lock smith
Well last night I went under the hood, opened the fuse panel and removed the "Memory"/Audio fuse, in my car it was yellow and only pulled up, not out, it was a "20". I left it out for a few min, pushed the fuse back in and everything is fine now, just have to reset my clock.
how can i get it warm enough to release the hood
