GE VG4270 VCR Logo
Question about GE VG4270 VCR
When I put a tape in the vcr the time flashes and I can hear a tapping sound inside the machine.
None of the buttons on the vcr or remote work. Several years ago there was a power outage while a tape was inside the vcr. The VCR wasn't on at the time. I was able to use the VCR after a few minutes, but it's been over 7 hours and the VCR still hasn't set itself.
Posted by dianakmullin on
Anonymous
    Genius:
  • 1,669 Answers
You have circuit board problems...time to retire it...they are cheap to rereplace!
Posted on Dec 26, 2012
2 Related Answers
Anonymous
  • 7 Answers
SOURCE: VCR shows "PLAY" on machine but doesn't show on TV
did you try pressing the TV/VCR button?
Posted on Feb 13, 2009
rad921
  • 132 Answers
SOURCE: Hi my vcr wont start up, sounds like the motor cant
belts inside a probably worn cheap fix if that is problem.
Posted on Oct 24, 2009
10helpful
My sony dvd slv-300p blue light progressive scan light is on and i cant do anything ?
my sony dvd vcr combo has a progressive scan flashing light when plugged in. i put a vcr in and now it's stuck. none of the buttons seem to be working. it is making a clicking sound inside on machine. how can i get this thing to work again?
How do i record a show onto a tape?
lets say you are hooked up correctly (cable to VCR in (from cable/sat box) & cable to TV from VCR out) and the VCR is set to Ch 3,, (PLEASE NOTE THE TV MUST BE ON CH 3)
program a recording
the VCR clock / date must be set and not flashing 12:00
then you go to menu, program a recording by imputing the start time / end time of the show and the date it will be recorded and Ch 3...(you might have to set your cable box for the same date/time as the VCR or manually turn to that ch you wish to record that morning or before you go to bed) put a new tape in the machine....
manual recording
a show,game or special comes on and you sitting and want to watch and record and even edit (no commercials) put tape in... press record button get the remote so you can pause (on commercials) and press pause again to resume recording
HAVE FUN
1helpful
I put a tape in and I hear a loud clicking noise and the VCR doesn't play the tape and turns itself off after 8-10 seconds.
first, try another tape. if it does the same thing the vcr is out of alignment. many times a broken lever inside the vhs tape can cause the vcr to shut down.
Sansui VCR/DVD
Cant' get remote buttons to work. No buttons work so can not watch DVD or Tape but can hear sound. Without the TV/VCR button not respondingnit won't switch over.
Dynex DX-R20TV flashes blue screen
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
2answers
If even the sound aside from the video is not reproduced on the TV, then your description "connect" indicates that the TV is not set to receive the audio/video signals from the VCR. Initially, pls try:
  • set the TV to Channel 3 (or 4); or
  • set the TV to A/V, Video 1 or Aux 1.
Additionally, you need to confirm how the VCR is hooked to the TV unit, bu a single coaxial cable or 3 cables with RCA connectors (yellow, red & white).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.Good luck and kind regards. Thank you for using FixYa.
Orion vcr troubles
hello . yes u have a belt slipping.that's what make's the tape eject. from the vcr. and you can fix it your self also.
Vcr does not respond to tv/vcr button on remote
You will not know from looking at the VCR if it is in VCR mode or TV mode. This is more likely a TV issue of whether the TV is monitoring the VCR or not. Make sure you have the TV selected so that it is monitoring the VCR.
That VCR/TV button has caused more confusion for the average person than anything else.
Hope Ya Fix It!
Flashing '2' or '1' or '4' when I try and play a tape
The idler on your machine needs to be changed and also the drum head of your machine needs to be clean.tape head cleaners can be bought from any electronic shop.the idler must be changed by qualified techn
VCR WILL NOT PLAY
The problem is the tape mechanism is malfuctioning. It trys eather to load or play a tape and a sensor inside tells the microprocessor to shut down this mechanism before damage is done to the tape. BUT sometimes a malfunction causes a damaged tape too. this unit has NO user serviseable parts inside itself, so its time to take this puppy into a repair shop to see if its worth the repair , Unless this units more then a few years old?? then its time to buy a shiny new unit. Good luck
Top GE Televison & Video Experts
Jaime Hernandez
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
