Televison & Video Logo
Question about Proscan Televison & Video
Proscan - model pldedv3292a - cannot get any channels
Model pldedv3292a it was working all of a sudden it stopped
Posted by Kathleen Schwartz on
Anonymous
    Genius:
  • 1,669 Answers
If you are on cable, make sure you didn't inadvertently switch off the cable box or switch the TV to HDMI if you are not set up fo it, or unset the chanel 3 setting on the TV so that the cable box can make the chanel selections....Check the owner's nanual, please!
Posted on Dec 26, 2012
Proscan PLEDV 1945A-B will not recognize cable. Auto channel scan results in no channels found
Do you have the converter box to convert the incoming signal from digital to analog, you must have this to receive broadcasts.
1helpful
Proscan PLDEDV3292A-B Powers up screen remains black but audio works fine. Sometimes you can turn off and back on and it goes to blue Proscan home screen as it should but now I have no blue screen.
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
I have a 32 inch proscan PLDEDV3292a which I have had for 17 months. It started having vertical lines on the right side about 6 inches. Can it be fixed?
If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations.
1helpful
Trying to hookup vhs analog player to hd proscan
your toshiba player should have output composite video and audio which are color coded Yellow for video, red and white for audio same goes for proscan hdtv. connect between the two keeping in mind color of cables. If the toshiba player is really old you can connect the RF cable output to antenna input to the proscan tv and watch taped programs from the player on channel 3 of the proscan tv. If then you want to keep the hookup and still watch HDTV connect the antenna to the toshiba vcr and when you shut off the vcr you can now watch the hdtv channels as usual because now you are bypassing the antenna to the Proscan tv. Hope this Helps..
My remote stopped working and there isn't any sort of # on the remote to know whqat to order to replace it. I have the proscan 32" 720p model with built in DVD player.
its may be the bulb a the front part,, while presing up and down channel move bulb with finger if change channel its a lose solder joint on bulb,, if not bulb maybe bad
Unable to get channels 14 through 98.
Make sure in the menu that you have the tuner set to Cable Mode, then auto program again. Hope this helps.
Unable to get channels after Channel 13.
Go into your menu and make sure the tuner is on Cable, then auto-program....Let me know?
Proscan model 52690
You can get the Phillips universal remote that will work that tv at the following link with free shipping. The phillips universal is one of the best remotes for a universal and easiest to program also
http://servicemanuals.vstore.ca/
Top Proscan Televison & Video Experts
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
