Question about Samsung DVD-HD841 DVD Player
I have a samsung hd841 dvd player. i need tv codes so i can program the samsung remote control to be able to use tv with same remote. thanx
I need the Emerson TV code model LC190em1 so I can use the remote control that came with the samsung dvd player to control the tv. The remote control model is a samsung 00025a.
Posted by BliTzer on
  • BliTzer Dec 26, 2012
    hey Tom normally you would be right. but the samsung tv remote is NOT programable but the samsung dvd remote is.. the dvd remote allows me to control dvd playeer of course plus 1 tv of my choice. i lost manual with tv codes. thanx
3 Related Answers
John-INSG
John-INSG
  • 312 Answers
SOURCE: need the remote control code for my samsung
Many universal remote control codes can be found at InsigniaProducts.com. Just click Support.
Posted on Jul 02, 2010
Anonymous
SOURCE: Samsung Blu ray code for direct tv remote
is there any remote that i can program tv,cable,direct tv,and blu-ray player all in 1
Posted on Jan 27, 2011
thecritter
Christa Dening
  • 29 Answers
SOURCE: Programming Code for a Toshiba dvd/vcr on a Samsung BP59-00048 universal remote control
If you haven't found the manual yet, you can download it from samsung.com's download center. Just enter your model number or search by product category.
Posted on Mar 01, 2008
What code do I use to program a cgi universal remote to a Samsung DVD player
How To Program A Samsung Remote To A DVD Player ' Codes For ...
codesforuniversalremotes.com/how-to-program-a-samsung-remote-to-a-dvd-player/
To program your Samsung TV universal remote control to your DVD follow these easy steps. ... component button (DVD) before you can use it to control your DVD. ... Samsung remote controls may not operate DVD players for all manufacturers
Mar 22, 2017 | Samsung Televison & Video
Tip
Samsung DVD-HD850, DVD-HD841 region free code
1. HDCP-Free: Requires only DVD Remote.
a. Power On DVD player, no disk inserted
b. Press "Angle"
c. Press "4", "3", "2", "7"
d. Press "Angle"
e. TV Screen displays HDCP Free
2. Region Free Hack: Requires AIWA/Universal Remote or PDA
The following instructions are for a Pocket PC
a. Download and install TvRemote
http://www.pdawin.com/tvremote.html
b. Download AIWA Mini Audio CCF file
http://www.remotecentral.com/ftp/ccf_templates/mini_systems/aiwa-mini-nsx999.zip
c. Copy the unzipped CCF file to your PPC
d. Run TvRemote on your PPC.
e. Switch to CCF mode on TvRemote
f. Open the copied CCF file. Screen changes to display
the remote.
g. With DVD switched on but tray closed:
i) Press "Repeat"
ii) Press "Program"
iii) Change remote screen and Press "Clock"
DVD display shows "ADJUST"
iv) Press "9" on DVD remote. I also pressed "9" on the
PPC remote so I'm not sure which one did it.
v) No visual indicators occur on DVD.
vi) Power off DVD.
h. DVD is now region free!
on Mar 07, 2010 | Televison & Video
Codes for bp59-00016 samsung remote to hook up a rca dvd player
Try the code 002 for an RCA DVD player for the BP59-00016 remote. This is the only code given for RCA DVD players for several Samsung TV universal remotes (BP59-0007 and the BP59-00016A). A manual for a TV with the BP59-00016A remote is here: http://downloadcenter.samsung.com/content/UM/200303/20030325191047000_L62A_ENG_1210.pdf .
You may need to check the age of the remote. The codes in a universal remote generally only control those devices released 6 months or more before the remote was programmed. If your RCA DVD player is newer than your remote, you may need a new remote.
I hope this helps.
Oct 12, 2011 | Samsung BP59-00016A Remote Control
Im trying to program a remote the tv is a zenith
Configuring codes:
1.Turn on a desired device (VCR or DVD player)
2. On the remote control, press a device key once (i.e., DVD/VCR,
CBL/SAT or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press DVD/VCR once. After programming a VCR Combo device, you will be able to control channel selection,volume, and VCR functions.
To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once. After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions.
To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer’s Codes to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly,
the LED will blink twice.
5. Aim the remote control at the device and press POWER once. The device should turn off. If it does not, repeat steps 2 to 5, trying each code for your brand until you find one that works. If it still doesn’t work, try Searching For Your Code on next page
Auto Code Scan:
1.On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice, then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly press POWER button.Stop when the TV turns off
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 to 5, but substitute the appropriate device key for the device you are searching for.
Thanx
Aug 06, 2010 | One For All URC4110 Remote Control
I need the code to program my hitachi remote control to a SDV290 Toshiba Dvd player?
1.Turn on the component to be programmed, such as the television or DVD player.
2.Press the "Code Set" button on your Hitachi remote. The button is often located near the top with the separate component buttons.
3.Press the button for the component you wish to program with the Hitachi Remote(TV,DVD).
4.Enter the manufacturer's code for the component being programmed. The manufacturer's code can be found either in the Hitachi manual, the manual for the component being programmed or on the website of the manufacturer of the product.
5.Press the "Enter" button to submit the manufacturer's code.
6.Press the power button for the component being programmed. Make sure the remote is pointed at the correct component, and it should turn on if the program was entered correctly
Thanx
Jul 29, 2010 | Hitachi CLU-5713TSI Remote Control
I have a universal remote and need the code for a magnavox dvd player to program the dvd player thank you
To get the code please go to below website
http://remotefinder.rca.com/default.aspx?site=rca
Please
Provide model of your remote
device to be programmed (VCR,TV)
Make name(toshiba,sony)
Thanx
Jul 28, 2010 | RCA RCU404 Remote Control
I have URC3220 remote and a Magnavox TV How do I program it?
PLease follow the steps below
1.Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
CBL/SAT,or TV).
or TV/VCR/DVD Player Combo press DVD/VCR once.After programming
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
then release SET.
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
6.You are set
thanx
Jul 24, 2010 | One For All URC4110 Remote Control
Trying to program sony triniton tv remote for my samsung dvd-vcr375 and can't find my manual for code
Hi
Please go to below website and you can fine the codes for your remote
http://esupport.sony.com/US/perl/select-system.pl?PRODTYPE=32
Please enter your Remote model number and you will get the code
Thanx
Jul 23, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
I need the remote control code for this unit to program into my TV remote
The Code you are looking for is 422. It is hard to find since it is listed only under DVD players and not combo players.
May 31, 2009 | Samsung DVD-V9800 DVD Player/VCR
Samsung DVD-HD841 DVD Player Logo
Demonic-2011
Demonic-2011
