Question about Dryers
Washer shakes violently! - Dryers
Posted by Stacie Morris on
Sandii
    New Friend:
Is your machine balanced properly? check the feet underneath and adjust if necessary untill level.
Your washing could be unbalanced inside the machine, open the door rearrange your washing evenly, turn back on, if this doesn't work maybe you have too much washing in the machine.
Posted on Dec 26, 2012
Leigh Perlmutter
    Genius:
  • Dryers Master
  • 1,669 Answers
Do you not know that unbalanced dry clotrhes become super unbalanced wet clothes! If you put too little clothing in the front loader, the weight will be in one place on the high speed turning drum. If you put in too much, the load will shift to a few locations but still be out of balance. Rather than "dance" the Chubby Checker way with your machine, try stopping it when it does "the dance" and redistribute the clothing around the drum!
My maytag washer is shaking violently on the rinse cycle
I am currently having the same issue with my Maytag A482. Not sure if you have found a fix yet, or if you have replaced your washer. My washer runs fine until it nears the end of the cycle, when it begins to spin and shake violently, enough to loosen the leveling feet and rock back and forth. I pulled the front panel of the machine off (two screws near the base in the front, and two clips at the top) and ran a load through it. It ran fine until the end, when the machine started shaking violently. I did notice a few small pieces of roundish felt looking material sitting on the bottom, which after some research looks like it may be the damper pad. I found these online:
Damper pad 203956
Replacement Damper 203725 for MAYTAG Laundry Appliances A482
I am hoping this will resolve the issue, I will order them this afternoon and install them once they arrive. I really hate to replace such a good washer with a new high efficiency unit, which all seem to have terrible reviews after a few months/year of use.
Aug 25, 2014 | Maytag Washing Machines
Crown series washer shakes violently on spin cycle
When you put on the clothes inside the spinner make it equilibrium to prevent shaking violently.
Jan 29, 2012 | Frigidaire FWSB5700DS Top Load Washer
Front loading machine shakes violently during spin
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 14, 2010 | Washing Machines
My brand new amana washer shakes violently when spinning
try adjusting the feet on the bottom of the washer the floor may not be level to adjust the legs turn them with a wrench or if the lock nuts are not tight turn the legs clockwise as you look at the front of the machine till all four feet are sung on all 4 corners. This is the most common problem. hope this helps and thanks for using fix-ya
Feb 15, 2010 | Washing Machines
Front load washer shakes violently during spin cycle
On something like this you will need to remove the washer wrap to inspect the suspension springs & base assembly. Please see the link provided for accessing the inside of the washer. Be sure the shipping pins have been removed. The tub should float freely.
Apr 03, 2009 | Washing Machines
Samsung P801 Front Loader shakes violently during spin cycle.
When the washer goes into spin cycle it is suppost to start at a slow speed and continue to increase speed (to a maximum of 800 RPM) as the water leaves the clothes. Your washer is going directly to 800 RPM which causes the washer to shake and stop giving you the E4 code. The control board that controls this speed increase must be replaced.
Feb 23, 2009 | Hotpoint Ultima WD72 Front Load...
Shook Violently first time on spin cycle
Make sure the washer is leveled properly and all four feet are resting on the floor. If it is level, try running one cysle without any clothes in it to see it is spins without that violent shaking.. you may have also had an out of balance load.. Hope that helps!
Aug 13, 2008 | Samsung WF337AA Front Load Washer
Frigidaire front-load stackable washer has violent shaking cycle
The Shipping bolts need to be removed from the back of the unit?? they go thru a plastic sleeve once the bolts are out you can twist the plastic peice to remove them completely I think there are 3 of them
Jan 24, 2008 | Frigidaire GLTF1670A Front Load Washer
Kenmore washer shakes violently during spin cycle
syrny,
Not sure what you did, exactly. First, does the machine shake when spun empty...and then with water only? If so, you have probably failed to tighten something or misaligned something. Go over your work.
No shakes? Rearrange your load. You may have a pair of heavy wet jeans which is throwing the whole thing out of kilter. It only takes about a half pound of sodden clothing to do this.
Nov 26, 2007 | Kenmore 22422 Top Load Washer
Dryers Logo
119 people viewed this question
Top Dryers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
