if the code does come back DO NOT RESET the machine again! It is indicating a problem the code you are resetting is the fuser and it can catch on fire! That will ruin a perfectly good day!!!
ENSURE YOU WAIT 10 SECONDS
1. Turn OFF the main power switch. (Located inside machine) Leave control power switch in the on position.) 2. Turn main power switch ON while pressing the Utility/Counter key. 3. Touch [Trouble Reset]. 4. Check to make sure that [OK] is displayed and the it has been reset. 5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
1. Switch machine off.
2. Hold up and down arrows in while switching the machine on.
3. Select Service menu and OK.
4. Scroll to 5.Mode and OK.
5. Scroll to 810 SC/Jam reset and press OK.
6. Execute
7. Switch machine off and on again.
If code does not reset you would need to replace the Fusing Unit and follow the above steps again.
Error code is regarding fixing unite.
1 check Teflon sleeve in fixing , if found damaged than replace,
2 check lower pressure roller and end rubber gear if found damage replace it
3 now start copier press buttons in following sequence
Addi. function *
than 28
again *
than on panel its display " COPIER"
touch it, than again touch on "FUNCTION"
Than Touch on "ERR"
than Touch "OK"
than switch off machine and again start.
machine will ready
E02" You may not have enough voltage going to the machine. Turn the machine off and on again at the switch at the rear of the treadmill. If this does not fix the problem you may have lower board problem see the diagrams attached and fix it. God bless you
Mr Thomas, this code means Fixing error, firsf switch on your Photocopier Machine then press 1,0,8,7 again 1,0,8,7 display will change will show u000. then press 1,6,3 press start key two times. machine will go off and on again. try that ,if will not work i will give you onather way.
Note that clearing the error may not necessarily fix the fault. Press the * with a circle around it then press 2 and 8 at the same time. Then press*again. Press copier touch button / function / clear / error /ok button then switch off. Switch the machine back on. The error code indicates that the machine doesn't sense the temperature of the fuser getting hotter. Usually this calls for the fixing film unit to be replaced because the thermistor has gone bad.
This error indicates that it cant detect the scanner unit of IRC3220
Check the cable that connect the machine and scanner unit .switch off the machine disconnect the cable and reconnect it and switch on the machine again hope this will help
the last error generated is from the fixing unit you have to clear the error again,but if this error code (Error 003) returned a thorough check on the fixing unit is needed.Or could be the AC supply to the machine is not stable.Go to program mode got o display> analog check the fuser/fixing temp hope this will help
The micro switch or the lever that activates it seems to have been the cause of the Error Code 43. Have re-seated the switch in its holder and ensured the activating (out of balance) lever is moving freely. The switch appears to be OK and now it is all re-assembled, the Error Code 43 is gone. Machine is operating normally again.
Out of Balance Switch was located below the right hand side of the computer board (module).
e002 error normally indicates that the heater {fuser} is off
to clear that in most canon models there is a small press switch is to be activated to reset the error
at the rear right side of machine there is a small cover take it out and look for that small black button, press it while or immediately after switching the machine ON , switch OFF and ON again
if the error still exist may a real damage in fuser e.g. blown thermo fuse or lamp
