Question about Audi Vehicle Parts & Accessories
Centrel locking won't open drivers door on my 2007 audi A6
Once the door has been opened with the key I can open and close the door fine until I lock it again. Then it's the same problem
Posted by Stewart on
Daniel Mc Entee
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Audi Master
  • 1,449 Answers
Change the central locking relay.
Posted on Dec 02, 2013
1 Related Answer
jmgldsmth
Jim Goldsmith
  • 2005 Answers
SOURCE: Honda accord 1995 driver door won't open
this is hard to do using a flashlight look into the door glass opening; locate the disconnected lever that attaches to the lock assembly
1. pull up on the lever or. 2. turn the lock cam located on the back of the lock
using a very long pair of needlenosed pliers
Posted on Feb 18, 2013
2004 Toyota Matrix. One remote works, other does not and battery is good. Is there a reset or any programming necessary? Last owner never used this dead remote and it sat in a closet. Battery's...
programing a remote is not hard but it is timing is every thing!
set up. driver's door open all others closed.
all movements are done at one second intervals.
1 insert the key in the ignition and remove it twice
2 close and open the door twice.
3 insert and remove the key once
4 close and open the door twice.
5 insert the key
6 close door
7 rotate key to run back to off and remove.
(locks should cycle once)
8 press both the lock and unlock buttons for a second on the remote.
9 press the remote's lock button (locks should cycle once more)
Jan 04, 2013 | 2004 Toyota Matrix
My Toyota 2001 rav4 remote light stays on it does nt open the doors alarm does not activate
The light for the keyless remote fob stays on? If so the battery may need replaced.
Here is link to a remote - LINK.IF this is yours get a battery @ your grocery store.
-open the key fob w/a flat screwdriver
-note the battery's position - is the '+' or the '-' visible?
-replace the batter the same way
-snap the cover back on
To reprogram (should also be in the Owner's manual):
1. Start with the key out of the ignition, drivers door is open all others closed and
drivers door is unlocked.
2. Perform these steps within 5 seconds.
A. Insert the key into the ignition(Do NOT Turn) Pull key out.
B. Insert the key into the ignition(Do NOT Turn) Pull key out.
3. Perform these steps within 40 seconds.
A. Close then open the drivers door.
B. Close then open the drivers door.
C. Insert the key into the ignition(Do NOT Turn) Pull key out.
4. Perform these steps within 40 seconds.
C. Close the drivers door
D. Insert the key into ignition and leave it in ignition.
E. Turn the ignition to ON (Do NOT Start) then back to OFF.
F. Remove the key from the ignition.
5. Within 3 seconds, the power door locks should lock then unlock automatically
indicating successful entry into programming mode.
Return to step 1 if the locks do not cycle at this point.
6. Perform these steps within 40 seconds.
A. Press the lock and unlock buttons on the remtoe simutaneously for 1.5 seconds.
B. Immediately after letting go of the lock and unlock buttons,
Press the lock button by itself and hold for 2 seconds. Within 3 seconds, the door
locks should lock and then unlock once indicating successful programming. If
the door locks cycle twice, repeat steps A and B in step 6 as the remote was
not accepted.
C. Repeat steps A and B in step 6 for each new remote.
7. Open drivers door.
Oct 18, 2012 | Cars & Trucks
When I unlock my 2002 vw golf all the electric windows open together ?
.Just to be sure, do you know that when you insert your key into either the driver or passenger (front) doors, and turn the key over to the far LEFT (in the process of unlocking the door), and hold the key in that position for more than a second or so, your windows will all roll down?? This is supposed to happen - it is a benefit of owning a VW! It is all described in the owner's manual.
Now the other side of this function, is that if when you get out of the car, and any of the windows are left open (including the sunroof if you have one), inserting your key and turning it over to the far RIGHT (in the process of locking the car), and once holding it there for more for a second or so, will then close all the windows for you. This opening and closing process will only continue for as long you hold the key turned over in the extreme position in either direction. Once you return the key to the center position, the opening and closing will stop. So you just hold it there until the windows are all closed. This option is not available via your keyless remote though - only via the key in the door locks.
It's something I love about the VW design - you can choose to let fresh air into the car before getting in without having to insert your key into the ignition and on the other side, if a window (or the sunroof) is accidentally left open when you've exited the car, you now have the option to close them all without once again inserting your key into ignition and turning it over.
Feb 18, 2012 | 2002 Volkswagen Golf
How do you program a replacement key for a lexus es 330 2004
Here are the instructions from the factory manual. They must be followed exactly.
2004 ES330
1. Driver's door open, all other doors closed, key removed from ignition switch.
Within 5 seconds:
Insert and remove the key from the ignition switch twice.
2. Within 40 seconds:
Close and open driver's door twice.
Insert and remove the key from the ignition switch.
3. Within 40 seconds:
Insert the key into the ignition switch and close the driver's door.
4. Switch ignition ON and OFF:
A. Once to program a key remote transmitter code whilst retaining the original codes.
B. Twice to program a key remote transmitter code whilst erasing the original codes.
C. Three times to check how many key remote transmitters are currently registered.
D. Five times to erase all registered codes.
5. Remove key from ignition switch. System should now lock and unlock vehicle
once, twice or five times depending which mode has been selected. One to four
times, slowly, to indicate number of key remote transmitters registered.
6. Within 40 seconds:
Press and hold LOCK and UNLOCK buttons simultaneously for 1.5 seconds.
Within 3 seconds: Press any key remote transmitter button.
System should now lock and unlock vehicle once to confirm registration or twice
to indicate registration has failed.
7. Within 40 seconds:
To program additional remotes repeat step 60 now on each additional
remote you want programmed.
8. To exit programming mode open driver's door or insert key into ignition.
9. Step out of car with remote(s) in hand and test remote(s).
Nov 01, 2011 | 2004 Lexus ES 330
I think I messed up the remote programing.. When I press to lock the doors they do lock but the horn doesn't honk anymore.. The blue light on the dash does not light up either.. I can still remote...
If the led is solid blue when the key is out of the ignition that means your in valet mode. Which would disable the alarm, but not the starter.
Simply turn key to IGN position then back to OFF.Push the valet button which is on the antenna next to the led and the led should turn off.Close door on vehicle and lock vehicle.Siren should now chirp.
Cheers!!
Sep 16, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Mercedes c class 2001 elegance, key fob not working everytime its pressed. I have had the batteries checked and they are still working fine, any advice as to what is causing this?
Most likely needs to be re matched to the car.
Two bits of info off the net for you
C CLASS (1993-1997), E CLASS (1995-1997), SLK (1996-)
Procedure
1. Point the remote control at the receiver - this should be located in the driver's door handle or next to the boot lock button.
2. Press the lock/unlock button.
3. Within 30 seconds manually lock or unlock the vehicle using the passenger's door lock or the boot lock.
Alternative method
Procedure
3. Within 30 seconds, switch the ignition ON.
Alternative method
Procedure
3. Within 30 seconds, turn the ignition switch to position II.
and
1. Place key in ignition lock and turn to position 2 [all ignition lights on]
2: Turn key to off position and remove from ignition.
3. Within 10 seconds:
3a: press the Close [Lock] button and hold it down
3b: while the Close button is still depressed simultaneously press the Open [Unlock] button. Press and release the Open button 5 times [still holding the Close button down]
3c: Release both the Close and the Open buttons at the same time, and immediately push any of the two Open buttons once [i.e. either the Open doors or the Open Tailgate]
This information is for the resetting of a previously synchronised key to match the security system after batteries have been removed or replaced. This information does not work with new keys which it seems must be taken to a person with a key synchronisation device [or a super-ripoff-expensive MB dealer]
hope this helps
Aug 13, 2011 | 2002 Jaguar X-Type
How to I reset my keyless 2005 toyota prius? I recently brought my car to a collision shop to change my driver's side door. They told me they unplug the battery cable. In doing this, now my keyless does...
KEYLESS REMOTE PROGRAMMING
1- Driver's door open & unlocked. Key out of ignition
2- Insert & remove key 2 times within 5 seconds
3- Close & open drivers door twice within 40 seconds
4- Insert key into ignition & remove
5- Close & open drivers door twice within 40 seconds
6- Insert key into ignition
7- Close the door
8- Turn ignition switch from "LOCK" to "ON" & back to "LOCK"
- ONCE for ADD mode
- TWICE for REWRITE mode
9- Remove the key from ignition
10- To confirm your mode selection, the power locks will now cycle "lock" to
"unlock" a number of times corresponding to your key cycles in step 8
11- Within 40 seconds of confirmation
- Press both transmitter Lock & Ulock buttons simultaneously
- Within 3 seconds press transmitter Lock button for more than 1 second
- If successful, the power locks will cycle once (twice indicates
transmitter problems)
- Repeat step 11 for additional remotes
12- Open door to exit programming.
Jan 18, 2018 | 2005 Toyota Prius
Step by step reset the door remote control lexus 400LS
1. sitting in driver seat, with driver's door OPEN, press lock/unlock button ON THE DRIVERS DOOR to lock all doors, then manually unlock driver door only.
2. Insert YOUR key in ignition, DO NOT TURN, then remove key.
3. Using the same lock/unlock button ON THE DRIVERS DOOR, slowly press lock-unlock in 5 cycles
4. Shut door.
5. Open door.
6. Using the same lock/unlock button ON THE DRIVERS DOOR, again slowly press lock-unlock in 5 cycles
7. With the door open insert your key into the ignition, turn to 'on' position (DON'T START), wait 5 seconds. Turn off and remove key.
8. Locks should cycle once (Car will lock and then unlock once by herself). If they don't cycle or they cycle more than once, do steps 1-7 over.
9. Now using the remote, push lock button, hold for one second, then release the button. The locks should cycle once. If not, start over and go slower.
10. Close the door.
11. Open the door.
12. Press the lock button on the remote. The locks should do a lock-unlock cycle.
13. Close the door
14. Press the lock button on the remote, the doors should lock.
15. Press unlock button and the doors should unlock.
Jun 16, 2009 | 1996 Lexus LS 400
Need the steps to programme the remote
Remote Programming Instructions
1. Driver's door OPEN and unlocked, all other doors closed and locked.
2. Insert YOUR key in ignition, DO NOT TURN, remove key.
3. Using the MANUAL lock/unlock button ON THE DRIVERS DOOR, slowly press lock and unlock 5 times (count the lock 5 times and unlock 5 times).
4. Shut door.
5. Open door.
6. Using the lock/unlock button ON THE DRIVERS DOOR, slowly press lock and unlock 5 times (count the lock 5 times and unlock 5 times).
7. With the door open insert your key into the ignition, turn to on position (DON'T START), wait 5 seconds. Turn off and remove key.
8. Locks should cycle once (Car will lock and then unlock once). If they don't cycle or they cycle more than once, do steps 1-7 over.
release. The locks should cycle once. If not, start over and go slower.
10. Close the door. Open the door. Press the lock button on the remote. The locks should cycle. Close the door. Press the lock button on the remote, the doors should lock. Press again and the doors should unlock.
Jun 02, 2009 | 1995 Lexus LS 400
Vehicle Parts & Accessories Logo
147 people viewed this question
Top Audi Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
ray gallant
Marvin
Marvin
Are you an Audi Vehicle Part and Accessory Expert? Answer questions, earn points and help others
