Maytag Quiet Plus II gas dryer squeaks loudly while running. I have seen easy to difficult responses on-line, and it would appear to be somewhat simple but not sure about attempting. Always better to call in a professional, however, thought I'd try in this day of on-line information.
It seems to me you need a new belt that go over and around the drum in witch you put the cloth first you have to go on line and find the rubber belt to replace it, may need make and modle or part number. you will have to take the top off first by removing the screws and then the front panel - the front panel has the electric on/off switch connected to it so be careful not to pull it apart. The rubber belt fits around the drum and then is attached to the pulley/drive motor. have a vacume handy to clean up the worn off pieces from the damage belt. Reattache the front panel and top of the dryer.
