Question about Danby DWC283BLS Wine Cooler
Need parts diagram for dwc283bls-1 - Danby DWC283BLS Wine Cooler
Posted by tony crawford on
hq120
    New Friend:
    Problem Solver:
  • 12 Answers
Http://www.searspartsdirect.com/partsdirect/part-model/Danby-Parts/Wine-beverage-cooler-Parts/Model-DWC283BLS/3055/0169000?pathTaken=&prst=0&shdMod=DWC283BLS
Posted on May 31, 2014
1 Related Answer
jim george
  • 6 Answers
SOURCE: Dandy wine cooler dwc283bls-1 has
temperature sensor open
Posted on Oct 27, 2010
Fans stopped working
go to sears parts direct and enter your DWC283BLS you will have the plan and number parts you need
Mar 15, 2014 | Danby DWC283BLS Wine Cooler
GASKET SEAL BAD
try at sears parts direct
Jan 13, 2014 | Danby DWC283BLS Wine Cooler
F230073 p c card
try there http://www.searspartsdirect.com/partsdirect/part-model/Danby-Parts/Wine-beverage-cooler-Parts/Model-DWC283BLS/3055/0169000/50031952/00001?blt=06&prst=0&shdMod=DWC283BLS
Dec 16, 2013 | Danby DWC283BLS Wine Cooler
MHello. We have a DWC283BLS-1 wine cooler. I got it from my aunt who had it in storage. The digital numbers on the front keep staying at 83 & 83. Every time I press the buttons to make the number...
It sounds like the Freon leaked down. That always happens when they are stored. Find a community college that has refrigeration classes and maybe they will look at it for you.
Dec 17, 2017 | Danby DWC283BLS Wine Cooler
Danby DWC283BLS has condensation inside the unit.
wine coolers have no means of draining the condensate inside them,use silica gel(1/2 pint)to keep the inside dry(remember to dry it out when condensate happens again)
Jul 16, 2010 | Danby DWC283BLS Wine Cooler
Describe your danby dwc283bls top fan does not work. after removing the fan ,the problem is no output from the logic board, defective board or another part,sensor etc.????
Hi,from your problem,it seems the problem is from the logic board,you can however use a mulimeter to read the voltage supplied by the board,if it reads a low amount of voltage it means the board need to be serviced and cleaned thoroughly,but if it reads no voltage at all meaning its not supplying no amount of power,it means the logical board is bad and needs to be replaced.
Thanks and take care
May 06, 2010 | Danby DWC283BLS Wine Cooler
Compressor runs and gets hot but does not cool unit
This product has been discontinued
i dont think many danby units are parts supported
more likely generic after market parts fitted by air con mechanics do the job
relay first might be a thematic one and an compressor motor fan relay
then check gas pressure
https://www.winecoolerdirect.com/danby-wine-cooler-dual-zone-dwc283bls/DWC283BLS.html
Service Manual.pdfwww.reliablepartsinc.com/danby/Manuals%20.../Service%20Manuals/DWC282%20%...
Mar 06, 2017 | Danby DWC283BLS Wine Cooler
Danby wine cooler repair
call Danby at 800 263 2629, you can order parts from them
May 10, 2008 | Danby DWC283BLS Wine Cooler
Danby DWC283BLS Wine Cooler Logo
591 people viewed this question
Top Danby Furniture Experts
Dennis Boxerman
jdthefixer
jasbo
jasbo
Are you a Danby Furniture Expert? Answer questions, earn points and help others
