When a press the power button nothing happen, computer don't turn on .
SOURCE: power switch does not turn computer on
If the switch has a (O) and (I) on it ,the (I) should be pushed in.
SOURCE: power problem
look for a switch on the back of the computer by the power supply it must be in the I position not the O . if that will not work then the motherboard my be damaged or the power supply itself not the cord for it is very rare for a power cord to polarize any more. last the power button itself may be damaged but in al my years I have not found a bad power button yet. Always it has been the motherboard or the power supply.
SOURCE: pc wont power up
Are all the installed drives functioning properly?
I've seen this with a bad IDE cable.
It may give a corrupt drive name in bios.
SOURCE: emachine T3624 will not power up
Emachines are notorious for having faulty power supplies. If your lucky you just need to replace the power supply. I've seen a lot of them where the power supply also fried the motherboard.
Please don't forget to rate this solution.
SOURCE: my pc fan and hard drive fans turn on when the
This could be a bad memory situation. Remove all the memory sticks and put just one back in. If it doesn't boot, try another stick (maybe the first stick is the bad one).
